  1. Hello, I've posted a similar question some months ago, and the suggestions I had were good enough to help me get what I needed so I thought I'd give another shot with this: http://www.lamarcardinals.com/collegesportslive/?media=407518
    It's a basketball game, usually I'm able to save these videos with Tubedigger or the KSV Adobe downloader, but for some reason, I'm not having any luck with this one.
    Tubedigger (I have a registered version, and have tried pretty much every single release from 4.7.5 on) will just save about half of the video. Actually it does a pretty weird thing which I haven't seen with any other site: when I start playing the video, the progress bar is already at 40% or so. I have tried emailing the developer to ask him about this but i haven't got any reply til now.
    With the adobe hds downloader, here's what i have at the end of the process:
    C:\PHP>php AdobeHDS.php --manifest "http://cbsicollege-lh.akamaihd.net/z/407518_
    lama9ZAOO@134905/manifest.f4m?g=FKOREYNDCEBG&hdcore=3.1.0" --parallel 4 --delete
    KSV Adobe HDS Downloader
    Processing manifest info....
    Quality Selection:
    Available: 1296
    Selected : 1296
    Downloading 232086090/232086090 fragments
    Found 0 fragments
    C:\PHP>pause
    I've tried many times, but I always have 0 fragments found. I've used this script 4-5 times before with different videos, and it always worked like a charm, so i've not messed with the switches (I wouldn't actually know what to try anyway).
    Thanks for your attention, and for your time
  2. Anonymous
    Guest
    http://cbsicollege-lh.akamaihd.net/z/407518_lama9ZAOO@134905/manifest.f4m?g=KLHILYDYHNBF&hdcore=3.1.0
    http://github.com/chrippa/livestreamer/releases
    livestreamer "hds://cbsicollege-lh.akamaihd.net/z/407518_lama9ZAOO@134905/manifest.f4m?g=KLHILYDYHNBF&hdcore=3.1.0" best -o 01.flv
    [cli][info] Found matching plugin stream for URL hds://cbsicollege-lh.akamaihd.net/z/407518_lama9ZAOO@134905/manifest.f4m?g=KLHILYDYHNBF&hdcore=3.1.0
    [cli][info] Available streams: 1296k (worst, best)
    [cli][info] Opening stream: 1296k (hds)
  3. Great, thank you!
  4. Hi ,
    @getupkid :
    @echo on
    php AdobeHDS.php --manifest "http://cbsicollege-lh.akamaihd.net/z/407518_lama9ZAOO@134905/manifest.f4m?g=KYYOCUPFVWMI&hdcore=3.1.0" --delete --auth "hdcore=3.1.0" --parallel 8 --useragent "Mozilla/5.0 (Windows NT 5.1; rv:32.0) Gecko/20100101 Firefox/32.0"
    pause
    :fin
    NOTEs :
    _ In your link , was missing :
    --auth "hdcore=3.1.0" --useragent "Mozilla/5.0 (Windows NT 5.1; rv:32.0) Gecko/20100101 Firefox/32.0"
    _ Added --parallel 8
    === Process ===
    Quality Selection:
     Available: 1296
     Selected : 1296
    Fragments Total: 232086090, First: 232084753, Start: 232084753, Parallel: 8
    Found 0 fragments
    Finished
    Got a file :
    85f8cd5b963fea813ad31fff79fe86cf_single_91a6c3b19250dc71-p_Seg1-Frag.flv (1 205 872 ko)
    ( No interesting video during the first time until 19'50" ).
    The fragments ( in the directory ) were not destroyed
    85f8cd5b963fea813ad31fff79fe86cf_single_91a6c3b19250dc71-p_Seg1-Frag232084753
    85f8cd5b963fea813ad31fff79fe86cf_single_91a6c3b19250dc71-p_Seg1-Frag232086090
    ??? are missing ???
    85f8cd5b963fea813ad31fff79fe86cf_single_91a6c3b19250dc71-p_Seg1-Frag232085334
    85f8cd5b963fea813ad31fff79fe86cf_single_91a6c3b19250dc71-p_Seg1-Frag232085335
    85f8cd5b963fea813ad31fff79fe86cf_single_91a6c3b19250dc71-p_Seg1-Frag232085336
    @nullacht : thanks .
    Cheers .
  5. use ffmpeg
    ffmpeg -i "http://cbsicollege-lh.akamaihd.net/i/407518_lama9ZAOO@134905/master.m3u8" -c copy video.ts
  6. Hi ,
    @CristianoA : Thanks for your reply . Your process is stopping while DL the video (???) .
    No longer receiving variant 1ze=    2033kB time=00:00:11.47 bitrate=1450.6kbits/s
    [hls,applehttp @ 02d05e20] No longer receiving variant 2
    [hls,applehttp @ 02d05e20] No longer receiving variant 3
    HTTP error 404 Not Found.0 size=   30663kB time=00:02:54.97 bitrate=1435.6kbits/s
    [http @ 028244a0] HTTP error 404 Not Found
    frame= 5251 fps= 41 q=-1.0 Lsize=   30702kB time=00:02:55.23 bitrate=1435.3kbits/s
    video:25735kB audio:2050kB subtitle:0 global headers:0kB muxing overhead 10.497217%
    Regards .
  7. Originally Posted by aazerty View Post
    Hi ,
    Regards .
    try
    #EXTM3U
    #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1296000,RESOLUTION=640x360,CODECS="avc1.66.30, mp4a.40.34"
    http://cbsicollege-lh.akamaihd.net/i/407518_lama9ZAOO@134905/index_single_av-p.m3u8?sd=10&rebase=on
    http://cbsicollege-lh.akamaihd.net/i/407518_lama9ZAOO@134905/index_single_av-b.m3u8?sd=10&rebase=on
    #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=96000,CODECS="mp4a.40.34"
    http://cbsicollege-lh.akamaihd.net/i/407518_lama9ZAOO@134905/index_single_a-p.m3u8?sd=10&rebase=on
    http://cbsicollege-lh.akamaihd.net/i/407518_lama9ZAOO@134905/index_single_a-b.m3u8?sd=10&rebase=on
  8. Hi ,
    Result , having used "index_single_av-b.m3u8" , same problem .
    Cheers .
