  1. I used to hardcode subtitles (foreign language parts) into my XVID videos using AVI Recomp.
    With the SSA format, the program allowed me to specify the font type and size as well as the positioning, is there anything similar with MKV video or is SRT and however the media player decides to choose for formatting?
  2. You can both hardcode or embed SSA subs into a video to be put into an MKV container.
  3. Originally Posted by manono View Post
    How do you hardcode?
    I presume with the embed, MKV Merge would simply do the trick.
    Any software I need to format the text?
    Oh, do you mean use AVI Recomp as I used to, and then import it to MKV?
    Any MKV specific tools...
  4. Originally Posted by pizzaboyUK View Post
    How do I hardcode? I don't. But if I were, I'd put the subs into an AviSynth script and open it in Ripbot264 and let it take take it from there. Or, if you,prefer, RipBot and other programs can open SSA subs separately. But many programs can hardcode SSA subs. As for embedding, yes, I use MKVMerge GUI.
    I use Substation Alpha. But other programs can do it or, if you know what you're doing, you can set the styles in Notepad.
    I've never used AVIRecomp in my life.
    I use Ripbot or XviD4PSP but, as I said, there are many.
  5. Any software I need to format the text?
    Subtitle Edit and Aegisub can convert .srt to .ass.
  6. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Assuming your media player can handle mkv files with embedded ass subtitles you can use Aegisub to format and position your ass or ssa subs then use mkvmergegui to put them in the mkv container with the audio and video. In mkvmergegui you can default and set the force flag. Whether your media player respects the flags will depend on if they are shown by default. The Popcorn C200 does for example. Otherwise if you want to actually burn them into the videostream you will have to do that in another program.
  7. Originally Posted by videobruger View Post
    I'm already using Subtitle Workshop to edit the subs - does a pretty good job...
    So, you can format and position subs without having to hardcode them?!?! Looking into this right away!
