I read that the sound decoder of TMPGEnc wasnt the best, what software can i use to achieve the best audio quality in VCDS-SVCDS?
Thanx
I've heard that there's something called tooLame that you can use with TMPG. I haven't really had any problems with the sound quality with just the standard TMPG though.
I thought that so, but yesterday i tried one of my SVCDS on a friends Home Theatre (with an incredible sound equipment) and the sound worked fine, but he played one of his VCDS and the sound was SPECTACULAR!.
I use tooLame to encode the audio for my SVCDs. It encodes the wav to an mp2 file great, but when I multiplex it to the video file with TMPGENC, the quality seems to degrade. I get a weird buzzing/humming noise. It's slight, but still noticable. Better than TMPGENC's audio encoding though.
Ok, little tips that will help with sound.
Go to doom9.org, go to the downloads section and get these apps (under audio, you'll need to select show all)
tooLame
SSRC
Set these up as external tools in TMPGEnc.
Don't multiplex using TMPGEnc, use bbMPEG (it gives better results).
If you don't mind a bit more complicated stuff use BeSweet to do your DVD audio (guides and download also at doom9).
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
n00b saving in Ulead for svcds and dvds myspace
By dsound in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2008, 12:40 -
2.5.3300 SVCDs getting recoded
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 15th Oct 2007, 21:44 -
Winavi v8 SVCDs jerking with SVCD2DVD
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 13th Jun 2007, 16:02
