Hello,
I am using Pinnacle PCTV to capture from my Hi8 Video camera, using VirtualDub. I am not dropping any frames and am capturing at 352 x 288 PAL format.
The resulting .avi looks very good but when I convert it to .mpg in tmpgenc, using the VCD/PAL template, the resuling .mpg is loosing some sharpness. I have compared the frames and there is some loss of quality. In tmpgenc, I have selected 'Motion Search Precision' as Highest quality.
Any help will be greatly appreciated.
Thanks,
Rohit
Hopefully you are using huffy compression. Try capturing at 352x576. This should make a significant increase in sharpness.
Yes, I am using huffy compression.
I tried at 352 x 576, but the picutre then appears long. Is it correct.
Regards,
Rohit -
well the thing is that it is usually best to capture at a higher resolution than your final output (352x288). The encoder should automatically resize the video.
Yes, you should capture at 352x576. It doesn't matter if the video looks long, it will be converted to 352x288 in encoding. I usually don't see a lot of difference between the AVI and mpeg file, unless there is a lot of action. The Tmpeg encoder does a good job, and on static images, the sharpness should be pretty much the same between the AVI and the mpeg (VCD) file. If yuo see a big difference, then you might have a poor mpeg decoder installed, or you are viewing the files at 2X or 3X real size. When blowing up files, there will often be a big difference depending on what algorithm is used for the resizing. So, compare the files at 1X size.
How to downsize MPG files with least quality loss
By windranger in forum Newbie / General discussionsReplies: 11Last Post: 28th Mar 2012, 14:37 -
Converting Multiple Audio Track MKV's to avi without Quality loss
By OrtegaSeason in forum Video ConversionReplies: 4Last Post: 6th Feb 2011, 07:09 -
MPG editing without quality loss?
By spup345 in forum EditingReplies: 7Last Post: 20th Jan 2010, 16:15 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
cutting out scenes without loss / converting mpg to avi
By denadel in forum EditingReplies: 3Last Post: 19th Jan 2008, 08:18
