  1. Hi. I recently had to re-build a MKV file because my HD player didn't read subtitles in SUB+IDX format.
    Therefore I extracted the subtitles, I ripped them in a more suitable form (ASS, SRT or so) using Vobsub than I made a brand new MKV using the video and audio channels extracted from the original movie and the new subtitles I created.
    What I wasn't able to do is to re-import the chapters. MKVExtrat GUI extracts the chaptes in a .xml format, and I haven't seen, in MKV Merge how to import such chapters file. What have I to do?
    In mkvmergegui under the top menu(not the tab) Chapter Editor->Load and import the xml.
    And mkv is not blu-ray authoring. Moving you to our video conversion section....close enough.
  3. I'm not sure you need to use MKVMergeGUI's chapter editor. You can add existing chapters to MKVs under the Global tab and the chapters section near the bottom. It'll load xml chapter files.
    Keep in mind you don't actually need to extract streams in order to mux them into a new MKV. For example you could open your original MKV with MKVMergeGUI, add the newly created subtitles, deselect the original subtitles if you want to, re-order the tracks if you like, then save that as a new MKV. If there were chapters in the original MKV, they'll be carried over to the new one along with the original video and audio etc, as long as you don't de-select them in the tracks list.
    Doing it that way is often a good idea as it allows MKVMergeGUI to keep the sync between tracks the same, so you don't need to worry about that sort of thing yourself. For example if the audio stream had a delay relative to the video in the original MKV, it'll have the same delay in the new one.
    You can do the same with other file types as the input. AVI, MP4, etc.
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Slightly off topic - a good source of chapter xml files is here
  5. batch expert Endoro's Avatar
    Dec 2013
    Bozen
    mkvextract chapters source-filename > chapter-filename
    mkvpropedit target-filename --chapters chapter-filename
    mkvextract.doc
    mkvpropedit.doc
    Dec 2012
    The Palatinate
    Last edited by Lowlander; 12th Sep 2014 at 13:02. Reason: Sorry, double post of hint how to avoid extracting anything at all, trying to figure out how to delete this.
