Can someone help understand this? I got some inconsistent size results from what should be a simple video conversion.
Background:
I have a script using handbrakeCLI 0.9.9 (named hbc99.exe in my script), to process a directory, converting any of 6 types of video file to .mkv files of the same size and quality (variable at my need) with avc video and aac audio. I was testing speed, when I discovered something weird. IT DOES NOT PRODUCE IDENTICAL RESULTS WHEN RUN MULTIPLE TIMES THE SAME FILE.
The script and conversion command uses variables, but after substitutions looks like this:
hbc99.exe -i "input.mp4" -t 1 -o ".\converted\input.mkv" -e x264 --x264-preset veryfast -q 24.5 -a 1 -E faac -6 dp12 -R Auto -B 128
So, I took a 2 minute 20 second test clip from a 1280x720 Grimm episode:
10/05/2012 10:50 PM 14,777,964 Grimm S02E06.mp4
and ran the script 5 different times, saving the result off after each run. I expected to get an identical result. Instead, I got:
09/08/2014 01:02 PM 11,914,189 Grimm S02E06 H1.mkv
09/08/2014 01:04 PM 11,913,494 Grimm S02E06 H2.mkv
09/08/2014 01:21 PM 11,914,280 Grimm S02E06 H3.mkv
09/08/2014 01:37 PM 11,915,120 Grimm S02E06 H4.mkv
09/08/2014 01:39 PM 11,914,042 Grimm S02E06 H5.mkv
ALL slightly different sizes. Not very different, but why does HandbrakeCLI NEVER seem to produce the same result?
FYI, the MediaInfo on all 5 files is identical (except for the 'uniqueid' and 'complete name' of course).
Any thoughts or solutions? (I actually ran 5 more times and still never hit the exact size on any of them.)
Because of the way it's multithreadd x264 does not produce exactly the same output very time when multithreading is used. See the "non-deterministic" option.
