I have an asx file that I tried to convert to VCD but the resulting file has no sound. I can play the file in MediaPlayer with sound. I have other asx files that worked OK with TMPGEnc (I renamed them to asf before conversion). What is the problem here? Is there some odd audio codec that is used in that file that did not work?
What you need to do is capture the audio to a .wav file.
The best way to do that is to use TotalRecorder.
Then once that's done, in tmpg use the asx as your video source and use the wav file as your audio source.
Try that, it works for me
help please, no sound when I've converted with winavi
By loadabull in forum Newbie / General discussionsReplies: 3Last Post: 7th Aug 2011, 03:57 -
the sound in my converted videos IS there, but some programs wont play it?
By extent in forum Video ConversionReplies: 8Last Post: 30th Aug 2010, 16:38 -
How to play asx files when inernet is offline ?
By cdstoke in forum User guidesReplies: 5Last Post: 27th Jan 2010, 10:46 -
No sound when converted, going top ipod, using SUPER
By wolfman13 in forum Video ConversionReplies: 1Last Post: 2nd Feb 2009, 10:17 -
alltoMKV converted MKV file sound out of sync.
By necrobutcher in forum Video ConversionReplies: 1Last Post: 10th Jun 2008, 17:25
