  1. Hello Everybody I have a question
    I have a DENVER-311 model and it's multiregion. But I'f I one day had a movie that was RCE-protected, what should I then do???
    Should I switch my DVD-player over to Region 1???
  2. You'll have to try, it depends how the multiregion is done.
    I have a multiregion DVD player or I should say a no region DVD player (set to region 0) and it refuses to play RCE DVDs like Hollowman or the patriot.
    If you can change regions then you should not have any problem.
  3. Can you set your player to any specific region? The way RCE works is that it asks the player if it can play region 1, then asks about region 2, etc. If it gets a "yes" answer for more regions than the one the disc is encoded with, it fails to play.
