    Sep 2014
    united states
    I'm pretty new at this conversion stuff, so I need a little help.
    I'm currently using the VLC media player to convert files into a .mp4 file so I can watch them on my blu-ray player seeing as it wont read the .avi files I have. I've noticed that about half the videos I've converted have a problem with the audio being synced up. I know if I'm watching the videos on my computer I can easily press the 'J' or 'K' key to adjust the audio timing (which is off by approximately 12,000 after the conversion), but I can't do that on my blu-ray player. can anyone tell me if there is a way to adjust the audio timing so that it syncs up after the conversion?
    thanks in advance
    I would try convert with something else first. Like the free vidcoder. Convert to mp4.
    Sep 2014
    united states
    thanks alot, that worked out perfectly
    Great!
    Aug 2017
    U.S. of A.
    RE: Baldrick Yes, you guided the O.P. to a program that worked, but you didn't answer his question. I too, am having the same problem. I've used PRISM and it works most of the time. But, just why is VLC not "ripping" in sync and can that be remedied?
    Rick
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Yes. I solved the problem. Try something else.
    VLC might work better now 9 YEARS later though.
