  1. Will not update the whole suite CS5 actually. Im attaching the msg i receive! Any ideas on why this might be happening?
    Try again later.
  3. Originally Posted by Baldrick View Post
    Try again later.
    ? i dont get it
    Apr 2003
    Are you using the update in the program itself? Try downloading the installation file to your hard drive and then run it:
    http://www.adobe.com/support/downloads/product.jsp?product=98&platform=Macintosh
    EDIT: the link refers to 5.0.4 being for the retail DVD version only. Later versions can also be downloaded from above link.
    Brainiac
  5. Do i have to download 5.0.1, 5.0.2, 5.0.3 and then install 5.0.4? Or are all the other versions included in 5.0.4?
    Apr 2003
    According to Adobe the updates are cumulative, meaning updates contain prior updates.
    Brainiac
