    Sep 2010
    India
    Hi,
    Just a quick question. If I have a avc video file with constant bit rate of 1500, does it make positive quality change if I increase the bit rate?
    canada
    Nope,increasing the bitrate on a re-encode will never increase quality.Filtering might help issues.
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    It's like taking a 720x480 dvd video and thinking that re-encoding it to 1920x1080 will make it HD.
  4. Take a wrinkle free piece of aluminum foil (uncompressed video). Scrunch it up into a 1 inch ball (compress to 1500 kbps). Open it up flat (uncompressed video). Note how wrinkled it is. Scrunch it up into a 2 inch ball (recompress to 3000 kbps). Open it up again (uncompressed video again). Is it more wrinkled or less?
  5. The scrunched up aluminium foil analogy.... that's one I've not heard before.
  6. I'm a Super Moderator johns0's Avatar
    canada
    So if i re-encode a video i will see wrinkles?
    Sep 2010
    India
    ok...thanks everyone....
