so the wwe network today uploaded 100 or so episodes of nitro. i am in the process of capturing these nitros. but my question is how do i make a blu ray disc with the nitro episodes on it as a br disc. i want it so i can play it on a blu ray player. how many episodes can i fit at 45min an episode? basically what im asking is for a program where i can just open it up, load a few nitros on a disc and create as blu ray
You can try trials like tmpgenc authoring works (blu-ray menu support) or free software like ripbot264, avchdcoder, etc (no blu-ray menus).
Using low resolution(720x576) and low bitrate can you probably fit all 100 episodes on a BD50(dual layer bd)...
Or just burn them as mp4/mkv files and many blu-ray players might support them directly. -
i think its easier if i just put as many nitros on a br disc as i can. should be around 15-20 episodes. i burned a br using ashampoo just for a test and it worked playing on my blu ray player. awesome
managed to fit 15 nitro episodes on one 25gb br disc
without any authoring. my blu ray player plays br data discs no problem
