Hi.
I want to convert my Bluray iso's to mkv files. I have quiet allot so i batch job would be ideal. I like to only include the DTS-HD/Dolby HD track and leave the rest behind. And then keep the video as it is along with all the subtitles.
What i found so far is DVDfab but can it be run as a batch and how?
Also looked at MakeMKV batch converter but i don't think it can remove the other audio tracks. Also i couldn't get it to work.
Any suggestions is very welcome.
An alternitive and free way is, you use chapterEditor - Multi-Editions-Editor(MEE).
You need eac3to and MKVToolNix.
MEE helps you to create a multi-edition-mkv with just a few clicks.
MME accepts input direct from a BD(with AnyDVD) or a BD-Structre from your hard drive.
eac3to scans the BD an show all information.
Select all editions yon want to combine. Go to the track section and deselect what you don't need.
With the mmg button you get a mmg-file. Double click it and start the mmg-muxing process.
MEE is like Xin1Generator but with a lot of more functions.
The created mkv have a chapter.xml inside with all editions which you can select in a player. (LAV or Haali required)Last edited by hubblec4; 8th Feb 2015 at 16:17.
