Trying to work out what resolution I should be using to get the highest quality without using a higher res than I need.....
Thanks.
European video standard with image format 4:3, 625 lines, 50 Hz and 4 MHz video bandwidth with a total 8 MHz of video channel width.
PAL uses
YUV.
In composite NTSC, PAL or S-video systems, it is necessary to scale (B-Y) and (R-Y) so that the composite NTSC or PAL signal (luma plus modulated chroma) is contained within the range -1/3 to +4/3. These limits reflect the capability of composite signal recording or transmission channel. The scale factors are obtained by two simultaneous equations involving both B-Y and R-Y, because the limits of the composite excursion are reached at combinations of B-Y and R-Y that are intermediate to primary colours
If your making a VCD
MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps -
For both PAL and NTSC, full broadcast resolution is achived when you capture at 640x480(576) pixels.
PAL - what is its resolution in 16:9 broadcasts?
By snadge in forum DVB / IPTVReplies: 19Last Post: 22nd Oct 2013, 07:01 -
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 02:10 -
Viewing PAL broadcast on a widescreen LCD TV
By streambuffer in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2011, 14:10 -
how to convert ntsc to pal without changin the resolution?
By Remyisme in forum Newbie / General discussionsReplies: 6Last Post: 27th Mar 2009, 18:30 -
PAL is bigger resolution than NTSC....?
By snadge in forum Newbie / General discussionsReplies: 17Last Post: 19th Jan 2008, 13:18
