I uploaded a 1280x720 59.94fps x264 mp4 video to youtube, and I could only get 29.97 on the there even though it qualifies 720p and 60fps. here are the media info for the video I uploaded, and the media info for the youtube 720p video. can you tell me what settings I need to change for youtube generate 60 fps? thx
Originally Posted by mineGeneral
Complete name
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 405 MiB
Duration : 4mn 29s
Overall bit rate : 12.6 Mbps
Encoded date : UTC 2014-08-30 02:02:53
Tagged date : UTC 2014-08-30 02:02:53
Writing application : Lavf55.8.103
Video
Format : AVC
Format profile : High 10@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : avc1
Duration : 4mn 29s
Bit rate : 12.4 Mbps
Maximum bit rate : 22.3 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.224
Stream size : 396 MiB (98%)
Writing library : x264 core 142 r2453kMod ea0ca51
Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / fade_compensate=0.00 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=150 / keyint_min=15 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=25.0000 / qcomp=0.77 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Matrix coefficients : BT.709
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 4mn 29s
Duration_LastFrame : -3ms
Bit rate mode : Variable
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 8.23 MiB (2%)
Tagged date : UTC 2014-08-30 02:02:53Originally Posted by youtube 720General
Complete name
Format : MPEG-4
Codec ID : mp42
File size : 103 MiB
Duration : 4mn 29s
Overall bit rate : 3 194 Kbps
Encoded date : UTC 2014-08-31 22:25:10
Tagged date : UTC 2014-08-31 22:25:10
gsst : 0
gstd : 269373
gssd : B18F41388MH1409532381176379
gshh : r5---sn-ni5f-t8ge.googlevideo.com
Video
Format : AVC
Format profile : High@L3.1
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 4mn 29s
Bit rate : 3 000 Kbps
Maximum bit rate : 8 147 Kbps
Height : 720 pixels
Frame rate : 29.970 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.109
Stream size : 96.3 MiB (94%)
Tagged date : UTC 2014-08-31 22:25:13
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 4mn 29s
Bit rate : 192 Kbps
Maximum bit rate : 202 Kbps
Stream size : 6.16 MiB (6%)
Title : IsoMedia File Produced by Google, 5-11-2011
Encoded date : UTC 2014-08-31 22:25:12
AnonymousGuest
Originally Posted by mineOriginally Posted by youtube 720Last edited by muffinman123; 31st Aug 2014 at 21:53.
Yup YT not support 60fps. But YT does support Webm, transcode your clip to Webm as alternative.
