Results 1 to 13 of 13
    Aug 2009
    New Zealand
    what possibly free app out there can i use to capture my vhs tapes too 720x576 4:3 mpeg2 .mpg plz
    thanks
  2. There's no 'app' and nothing free. Between the VCR and the computer you have to install a capture card, a USB capture device, a DV device such as a Canopus box, buy a DVD recorder, take your pick.
    With a little looking around you can find many suggestions and solutions.
    Aug 2009
    New Zealand
    yes i have a usb capture card on my pc im running windows 7 what app can i use to rec to .mpg
  4. Why did you not write ALL information on first post?
    usb capture card comes with capture software.
    Aug 2009
    New Zealand
    mine was given too me by my mate without the cd
    i know i can use virtualdub but i want to rec the videos too .mpg
  6. You can download from manufacture capture card site
    but don't know if its capture in mpeg2 file
    Aug 2009
    New Zealand
    there is no name on the usb capture card
  8. Member DB83's Avatar
    Jul 2007
    Look at the 'Software' section of the site for 'capture' tools. Some are free.
    The issue is the drivers that your card supports so, since you do not even know what that is, you will just have to try them. And without drivers the card will not work regardless of software.
    My guess is that it is a easyc(r)ap and drivers are not so easy to come by for Win7
  9. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Does the device show up in the list of connected USB devices, and/or whatever Win7 is calling the Device Manager these days? Whatever name it appears under might provide a clue. Also, it's probably a long shot, but it might even help to post a picture of what the USB capture device looks like here. Someone may recognize it.
  10. Member DB83's Avatar
    Jul 2007
    Start/Control Panel/Device Manager
    Actually easier to find than with XP
    Aug 2009
    New Zealand
    i have installed honestech TVR 2.5 but when i rec a video the video stops all i can hear is audio and when i play it back its only rec 5sec and looks like a slide show my computer is fast its an i7
  12. Member DB83's Avatar
    Jul 2007
    Now what part of
    "The issue is the drivers that your card supports so, since you do not even know what that is, you will just have to try them. And without drivers the card will not work regardless of software."
    do you not understand ?
