I have been trying to install Acid 3.0f on my system (downloaded the demo copy, but have a similar problem with a friend's registered copy). Every time I install it my mpeg-2 playback is way out of synch (about 8 seconds or better). This is when I playback using WMP, PowerDVD, or ATI File Viewer so it must be some sort of codec issue.
As soon as I roll back the Acid install everything is back in perfect synch. Any ideas??
(Running XP pro, Athlon 1.1, 640Mb).
Thanks.
It install mpeg2 demultiplexer with it. This DS filter provides time stamps on output video and audio streams, and it do not work correctly, so video and audio renderes can't synchronize.
Go to vcdhelp codecs http://www.vcdhelp.com/vcdtools.htm and download one you like. Elecard is the best of course :-)
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38 -
Virtualdub codec MPEG-2 / MPEG-1
By Astrogirl in forum Video ConversionReplies: 19Last Post: 10th Dec 2008, 12:38 -
Mpeg-4 to mpeg-2 for mac/adobe premiere pro......
By macbookuser in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2007, 22:48 -
Where Am I Messing Up?
By aeuzent in forum Authoring (DVD)Replies: 5Last Post: 23rd Jun 2007, 03:09
