Hi,
MediaInfo reports the matrix:
Format settings, Matrix : Default (MPEG) -> original file
I've already tried encoding a file with h.263 matrix:
Format settings, Matrix : Default (H.263)
without success.
I've also tried to mux the original video with a different audio track (MP2 format) and it works.
Instead, the recompressed file with no audio doesn't play (the original video with no audio plays).
I label my trials in filename but until now, no encoded video worked.
I'll try with AmiDemux and DivX codec. For Xvid codec settings, I've already tried disabling everything
Where to set "adaptive quantization" in the codec ?
I've noticed that MPEG4 Modifier reports different information:
- original door phone file (182929_DOOR1.AVI)
Packed bitstream: No
QPel: No
GMC: No
Interlaced: No
Aspect ratio: Square pixels
Quant type: MPEG
FourCC: XVID
User data: Zoran
- recompressed file (182929_DOOR1_recompress.avi)
QPel: No
GMC: No
Interlaced: No
Quant type: MPEG
FourCC: XVID
User data: Zoran
I-VOPs: 6 (5,88%)
P-VOPs: 96 (94,12%)
B-VOPs: 0 (0,00%)
S-VOPs: 0 (0,00%)
N-VOPs: 0 (0,00%)
This information is not present on original file:
I-VOPs: 6 (5,88%)
P-VOPs: 96 (94,12%)
How to encode a video without I-VOPs and P-VOPs ?
Thank you.
Best regards,
cdr
				Results 31 to 50 of 50
	You encode without P frames by setting the I frame interval (GOP size) to 1. You can't encode without I frames. I don't know why Mpeg4Modifier reports the frame type statistics with other AVI file but not the devices files.
	Thank you but with GOP size 1, are there only keyframes ? The original file has keyframe interval = 20, as stated by GSpot. I've set Xvid codec to have the same keyframe interval without success.
 It'd be interesting to discover why Mpeg4Modifier doesn't report I-VOPs and P-VOPs of device files...
 Edit: I've tried Avidemux but Xvid settings are different and less complete from those with VirtualDub. It is not possible to select profile Advanced Simple@L5 but only till L4...
 Best regards,
 cdrLast edited by cdr400; 2nd Sep 2014 at 04:41.
	Yes.
 Yes, I know.
 If you open a large XVID AVI file with the program you can see that it scans through the entire file. Presumably that's how it determines the frame type statistics. Apparently it's not scanning the files from door cam and isn't giving an error message.
 Did you try the resulting file anyway?
	Have you tried hexediting to include that TrustCKType info header?
	Any other ideas ?
 Is it possible to take the complete avi header of the working file and overwrite the one of the bad file (with the same audio track and duration) ?
	Yes, but you'll have to tweak the durations (or other fields if dur is same) and it might have problems seeking, etc due to the change in packet positioning. This might be fixable with a remux, though.
 Give it a try, what's the worst that could happen?
 I have successfully done this before when repairing/restoring some corrupted files (.MOV & .AVI), but it takes a while to get right.
	I have to ask again: why are you attempting this at all?
 It seems a shame to take a specialized tool such as a security/door cam/monitor and make it do double duty as a standard "digital photo/video frame", particularly when you could get one of those for much cheaper (~$25USD?) and have NO or MUCH LESS compatibility problems. (If this is what you're attempting).
	Thank you.
 Which tool have you used to overwrite avi header? A binary editor or a specific tool ?
 The video door phone is in perfect position in my living room, there is no space for another photoframe (btw, are you sure that a 9" photo video frame costs only 25USD?)
 Furthermore the display is always active (it is not possible to power off) so I prefer showing a video instead of a clock
 Another use is for my young children that like viewing video music file (and the browser of the door phone is very simple to use).
 Best regards,
 cdr
	I've used a hex editor combined with a structure viewer. So for MOV, I used Dumptster (which is now hard to find, but you might substitute MP4Explorer), and AVI I used Riff Viewer (there are others: abcAVITagEditor, RiffPad,...).
 Not the 9", but 7" or 8", yes I have seen those. Many are on deep discount because they haven't sold as well as was expected.
 [Humorous]OK, here's what you do: Make your video & show it on a monitor. Put the monitor in the FOV of the door cam and record the monitor as the video plays. Now there's a "doorcam-compatible" version![/Humorous]
 Good luck in you attempts.
	Hi, I've tried overwriting the header of the bad file (with same length) with the good one but it doesn't work.
 This is the method I used:
 - saved a file with only header of original door phone file
 - saved bad files (of the same length) without header
 - used DOS command: copy /b header+fileWithoutHeader fileToTest.AVI
 Is it correct ?
 Thank you for your humorous solution: it surely works !
 I'm serious to pay 5USD via Paypal to the one that provide me a working encoded file and explain me how to obtain it
 Best regards,
 cdr
	I don't recommend ever using the "Copy /B", as it is ignorant of well-formed packet management.
 Well, I tried just using a different muxer than Virtualdub (AVIMux-GUI, which always claimed to be one of the most versatile & compliant).
 Using a new piece of video, swapped out from the original piece of video, but with the original audio. Named the same as the original video.
 Let me know if it works, or if not, what it does (same freeze on black as before?).
	Hi,
 thank you for the file: I'll try it as soon as I'll arrive at home.
 I've noticed that audio stream is MPEG audio Version 1 while the original was Version 2 (Layer 2).
 Best regards,
 cdr
	??? That's weird, I remuxed your audio. OK, must be a quirk in the muxer...
	Hi,
 I've tried your file and it doesn't play: the door phone report immediately "Unsupport File" and the browser returns to the list of files.
 I've tried removing the audio stream with Virtual Dub and in this case the door phone shows the hourglass for about 5s before showing the same error; then it hangs with black screen.
 Any ideas?
 Thank you.
 Best regards,
 cdr
	I'm all out for now...will think about it.
 Ok, here's something to try:
 Shoot a number of different images WITH the door phone, such that the video in each is quite different but all of the clips play correctly. Then do a hex diff compare on them and see what elements are common to all. Won't be the video, should be most of the basic headers (discounting filename, duration & bitrate). Perhaps there is a proprietary tag somewhere inside the Xvid data stream that is hidden, but necessary for accepting playback.
	Hi,
 after many many tries with hex editor I've lost hope
 I remember the 5USD prize (via Paypal) for the one who sends me an encoded video that plays on my door phone and explains me how to obtain it.
 Thank you.
 Best regards,
 cdr
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
