Hi, i have video with a resolution of 1920X800 and i want to uncrop it to 1920X1080 without loosing aspect ratio.
what should i add to the command line for doing this.
for now i use this cmd and the final video is still 1920X800. when i try with any resize command, my movie become full screen (zoomed) :
--preset veryslow --tune film --bluray-compat --vbv-maxrate 40000 --vbv-bufsize 30000 --level 4.1 --keyint 24 --open-gop --slices 4 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1
**sorry for my english
thanks
Results 1 to 9 of 9
Do you use Avisynth? http://avisynth.nl/index.php/AddBorders
Or.... the ffdshow video decoder has a filter for resizing and adding borders. If you were to decode via DirectShow you could add the borders back that way.... Enable ffdshow's resize filter, set it to resize to 1920x1080, and make sure the "keep original aspect ratio" option is selected. ffdshow will then resize to 1920x1080 by adding the black borders for you. The picture itself should remain the same (not stretched).
Which encoding program are you using? -
i'm using Simple x264 Launcher with this command line:
I want to use this cmd because i want to make 100% bluray compliant file. It works great when my source is exactly 1080p . I just need to learn how to add borders with avisynth i guess .
I know that uncropmkv and multiavchd can do the uncrop but X264 in it , is completely outdated and you cant add my command line ... again i want 100% bluray compliant
Thanks for your replies guys -
Perhaps the AddBorders command is what you're looking for.
http://avisynth.org.ru/docs/english/ -
"vanilla" x264 builds are not compiled with a filtering patch, but some have "pad" filter.
06_taro's "tmod" builds have the patch compiled
http://tmod.nmm-hd.org/x264/
So you would add 140px to top and bottom each, just add the commandline. You might be able to drop in and replace the binary with simple x264 launcher (you might have to rename the binary to match)
Code:--vf pad:0,140,0,140
Or if you want to use avisynth
Code:AddBorders(0,140,0,140)
Assuming this is 23.976 source , unless you have 24000/1001 exactly in an avs script (which will feed CFR) - for BD you should also add
Code:--fps 24000/1001 --force-cfr
