Hey guys. I'm pulling out my hair here trying to figure this out. I've been googling and downloading every possible fix I can imagine and I just can't figure it out.. any help you can provide would be so appreciated..
So I was given 2 large (~7GB each.. lossless) .avi files that I'm trying to view properly in Adobe Audition and Premiere Pro. They were both recorded with mostly the same settings, save for a few small differences, but one will play properly in audition and one will not, even when converted! More irritatingly, the video file that's giving me problems plays properly in MPC-HC so I can't figure out what's wrong with it.
First off, one of the two files works just fine in both Audition and Premiere Pro. And I've tried viewing the problem file on multiple PCs with these programs and the result is always the same. I've tried converting them to mp4 (h264), but the problematic file STILL has issues. I've tried repair tools but it always gives me errors - I've tried demuxing the audio out (which is what I suspect is the problem), but whenever I do this in vdub or vdubmod, the resulting video file is more messed up than the original even in stream copy form.
I even tried recording MPC-HC playing the video file correctly.. which gave me somewhat improved results, but then the video just plays at super speed in both programs..
When I try to edit/view a capture of the file playing in MPC-HC OR the original AVI, the problem file plays its video way faster than it is supposed to.
When trying to view the file converted into MP4, the problem file plays fine up until halfway through the video and then the video cuts out and only displays a black screen.
The other file, which I've had no problems with at all, displays correctly in both programs as an MP4 file (h264).
The media info for File 1, the file that is easily converted and properly viewed in any program:
Format : AVI
Format profile : OpenDML
File size : 7.74 GiB
Duration : 17mn 57s
Overall bit rate : 61.7 Mbps
Original source form/Distributed by : Video:x264vfw - H.264/MPEG-4 AVC codec Audio:Speakers (Realtek High Definition Audio)
Writing application : DxtoryCore ver2.0.0.127
Video
Format : AVC
Format profile : High 4:4:4 Predictive@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : H264
Duration : 17mn 57s
Bit rate : 61.4 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 fps
Original frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:4:4
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.987
Stream size : 7.70 GiB (99%)
Writing library : x264 core 142 r2453bm ea0ca51
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=8 / lookahead_threads=8 / sliced_threads=1 / slices=8 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=cqp / mbtree=0 / qp=0
Matrix coefficients : RGB
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 17mn 57s
Bit rate mode : Constant
Bit rate : 320 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 41.1 MiB (1%)
Alignment : Split accross interleaves
Interleave, duration : 999 ms (29.98 video frames)
Writing library : LAME3.99.5
The media info for File 2, which has issues in both AVI and MP4 format:
Format : AVI
File size : 6.53 GiB
Duration : 17mn 53s
Overall bit rate : 52.3 Mbps
Original source form/Distributed by : Video264vfw - H.264/MPEG-4 AVC codec Audio:Speakers (High Definition Audio Device)
Video
Format : AVC
Format profile : High 4:4:4 Predictive@L5.0
Codec ID : H264
Duration : 17mn 53s
Bit rate : 52.0 Mbps
Height : 1 200 pixels
Display aspect ratio : 16:10
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.752
Stream size : 6.49 GiB (99%)
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=4 / lookahead_threads=4 / sliced_threads=1 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=cqp / mbtree=0 / qp=0
Audio
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 17mn 53s
Bit rate : 320 Kbps
Stream size : 41.0 MiB (1%)
Interleave, duration : 1000 ms (29.99 video frames)
Writing library : LAME3.99.5ªªª6 £à5‡
If you've read this far, thank you.. If you have any ideas or can help... THANK YOU! I tried to include as much info as possible.
Are you reconverting the video when converting to mp4? Or just remuxing to mp4(copy video and audio streams).
Maybe try resize to 1080 pixels. -
I tried both remuxing and converting, but I was not able to successfully convert because I got an error for almost every other codec I tried
I haven't tried resizing it though. I will try that. Thanks!
edit: actually, upon further reflection, I did re-encode it using handbrake. That did yield an MP4 file that behaved as I described the other one to behave (cutting off mid-playback in the Adobe programs only)Last edited by Poptartica; 25th Aug 2014 at 14:04.
