  1. only for Cats: please do you know Inscriber Titlemotion?
  2. Member Cornucopia's Avatar
    No, but if you hum a few bars...
  3. I repeat: it's an answer for cats. Have you use titlemotion HD by Inscriber technology?
    Oct 2005
    666th portal
    it's old and no longer sold or supported. why would anyone still use it?
  5. nothing, curiosity of my cat
  6. Member Cornucopia's Avatar
    This is not "Cathelp.com", but Videohelp.com, where there is no "only for..." threads. It's gotten old.
    I've used I.T., btw. It has been made as a title module for a number of NLE platforms: Premiere, Edius, Matrox, & your venerable Speed Razor. All of them (Title modules) are long in the tooth now, so I wouldn't recommend ANY of them.
    IIWY, I'd use BluffTitler, create your title as a separate piece of uncompressed+alphachannel (aka transparency) video. Then you can overlay that in ANY editor, including your old favorite. BluffTitler allows for all kinds of stuff: 3D look, particle effects, animation on a path (including the common scroll/crawl), Passe-partout cutouts...
  7. grrrr
