just what the topic says...
http://vcdimager.hvrlab.org/
I've noticed with this version that FF/RW work better than the previous betas on SVCD
Does this have to do with the file system ordering?
On the other releases the order was similar to Nero's and hence my FF/RW worked similar. Instead of the correct 20 secs at a time it would advance at different times 5,10,40,10 so on, unless presented with a CBR mpeg2 @ 2600kbits.
yeah, its about the picky firmware which requires some strange file ordering...
btw, a bug slipped through in 0.7.8,
vcdimager.exe (bu not vcdxbuild.exe!), triggers an assertion, if it is used without any --add-dir or --add-file option...
this bug is annoying, but a minor one, since u usually either add the CD-i app for VCDs, or an empty SEGMENT dir for SVCDs *g*
How to Author an SVCD with menus and stills Under GNU/Linux
By khey in forum User guidesReplies: 1Last Post: 24th May 2011, 23:35 -
Open source Firewal (GNU/GPL license), based on PC hardware solutions...
By retroborg in forum ComputerReplies: 2Last Post: 8th Mar 2010, 06:05
