Results 31 to 36 of 36
Thanx guys ( especially Cornucopia
) im taking into considerations all that you say!
Let me ask something else, just out of curiosity. Im wodering, after i make the joining if i decide to cut the joined video to multiple dv files and then join them back again, will the produced joined video be the same (in quality) as the first joined video or will there be any loss in quality?Last edited by zoranb; 29th Aug 2014 at 15:54.
When "smart rendering" dv (or any similar smartrenderable format), you can cut/join/cut/join as many times as you like because it is a direct stream copy from input to output.*
*Does slightly different things with Interframe codecs, where there is some loss on the boundary border GOPs. -
Is there any setting i must not select or should be aware of, when exporting the joined footage from Premiere CS5? Do you think it be best to set me up a preset of what you believe should be the best settings for the export command? Just thinking that it might be a good idea to guide me correctly, but certainly you don't have to do this
Everything has to match correctly. This means your footage, interpretation settings (what Adobe "thinks" your dv footage is), sequence settings, render settings
If one thing doesn't match (e.g. you accidentally chose 4:3 when it was supposed to be 16:9 , or 32000Hz, when it was supposed to be 48000Hz), Adobe will re-encode = lose quality
Ok
