When capturing should the timecode be a round number so that the frame is ok, or can i stop the time at any point i like? Say for eg the footage ends at 00:20:14:03, is it ok to stop it there of should i end it at 00:20:14:00 ?
I think i have seen that in PremiereCS5 there are some issues when ending the "out" at non round numbers!
Do i make sense? Is everyone understanding my point?![]()
Results 1 to 10 of 10
Depends on what codec you are capturing with: I-frame codecs (DV, Cineform, ProRes, Lagarith, etc) you can start & stop anywhere, Inter-frame codecs - when used interframe (MPEG2, DivX, AVC, WMV9, etc) depend on the app as to whether it handles the orphans frames in the GOP correctly (IP-type frames should be OK regardless, but IBBP-type can be problematic, PARTICUARLY open-GOP).
Premiere is not alone in this, all apps that cap + work with Interframe codecs would have to do special handling in order to manage them correctly. However, Premiere, as well as most other pro and semi-pro NLEs are probably built EXPECTING to use I-frame (or simple short-GOP) codecs for capture & edit.
ScottLast edited by Cornucopia; 24th Aug 2014 at 16:31.
Thanx for the extensive reply!
Im facing sync issues but when i fiddle with the in and out frames the issue is fixed! Do you think what im asking is relevant to this?
Well, it would help if you actually told us the setup/connections, apps, settings, etc. that you are using. You mention Premiere, but I can't tell if that is your capping app or editing app, or neither or both.
If you have already done some and want to know what it turned out as, get a MediaInfo readout (you could post the detailed text information here).
Scott -
Regarding MediaInfo, its just that i have no clue what to download. It has many options for the Mac but no clue which one is for my iMac!
Download the one for your OS version.
Mentioning you are on a Mac, and posting in the Mac sub-forum is really important. There are far fewer tools available. -
