MeGUI crashes with the following message: "Avs4x264mod.exe has stopped working". It will NOT continue encoding the next file in the queue until I close the message. Here's the error report.
My script is pretty simple as all I'm doing is some light denoising of some 1080i PAL satellite TV files & converting to 720p:Problem signature:
Problem Event Name: APPCRASH
Application Name: avs4x264mod.exe
Application Version: 0.0.0.0
Application Timestamp: 5221d3c6
Fault Module Name: DGDecodeNV.dll
Fault Module Version: 0.0.0.2047
Fault Module Timestamp: 53b80ab9
Exception Code: c0000005
Exception Offset: 0001431e
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 2057
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Does anyone know how to get MeGUI to automatically continue with the next encoding in the queue instead of stopping when an encoding crashes?Code:setmtmode(5,9) <input> setmtmode(2) AssumeTFF() DeGrainMedian(limitY=2, limitUV=3, mode=1, interlaced=true) Yadif(mode=1, order=1) Vinverse() Lanczos4Resize(1280,720)
Or even better if you know how to prevent MeGUI from crashing then please let me know! I know I could use non-MT but I don't wish to do so. The error report mentions DGDecodeNV which is a bit strange as I've never seen DGDecodeNV crash.
