    Aug 2014
    Kuwait
    After uninstall madVR the video in full-screen freeze when using enhanced video renderer and the sound continue
    Jan 2014
    Kazakhstan
    Which player use?
    Aug 2014
    Kuwait
    the must important to me is dvb dream
    Jan 2014
    Kazakhstan
    Then you better write it on a forum http://www.dvbdream.org/forum/
  5. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Have you tried to uninstall, reboot, reinstall dvd dream?
    Google is your Friend
    Aug 2014
    Kuwait
    yes but when install dvb dream it does not return to default settings and it still running under my settings
    I think the problem is that madVR has change something in my system that case the problem with EVR in fullscreen
