i have full one to one decrypted rips of blu-rays that i own and making the rips so they can be played on my media center and can put the discs away, anyways my question is with tv series like Game OF Thrones i want to be able to turn those into individual episodes (aka seperate mkv files) as apposed to one giant disc and wish to have all the subtitles and additonal audio tracks attached to each one plus i do not want any quality loss on audio or video and kept at 1080P.
is there an easy way todo this?
ok but what program can i use to take that decryped 1 to 1 copy and extract each episode of GOT to thier own MKV files with full 1080P and all audio tracks and subtitles? size of each file is not a problem for me.
One way to do it: MKVToolnix. Use the front-end MKVMergeGUI (mmg).
First you use MakeMKV to rip to *files*, not MKV.
Click "Add" and navigate to an *.mpls (playlist) file in the Playlist folder in your rip. Let mmg scan for all playlists. Add an episode, then add it to the queue. Repeat as necessary. Quality will remain the same, as all you're doing is "repackaging" the contents to MKV container.Pull! Bang! Darn! -
Pull! Bang! Darn! -
I'm pretty sure MakeMKV will separate them for you if they are separate files on the disc. You would just need to go to each one and rename it accordingly so you could tell which was which.
Also, why a 1:1 backup? To each his own, but Handbrake at RF18 with slow x264 preset looks pretty dang good compared to the source.
You'd have to rip the episodes one at a time.
