I'm stuck again. I'm in the advanced mixing options and I can't work out some of the channels. Crucially, I need to know the difference between FR - L and FL. Which is front left, and why isn't there an FR channel?
Also, do I select 8 channels for an 8.1 mix? What is Front L & R Matrix, is it the same as Side L & R in audacity?
Results 61 to 88 of 88
7.1 is 8 channels => this is what you have
8.1 is 9 channels , and not a common configuration
The naming convention was given in an earlier post FL+FR+FC+LFE+BL+BR+SL+SR . That's the order you should use
If you are using mediainfo names, the Front L (matrix) would correspond to SL , The Front R (Matrix) would correspond to SR
If you look closely at mediainfo the audio #1 is FL, audio #2 is FR, etc.... they corresond to the order given above -
I don't know why you're doing this ? video stream only ?
Did you want video stream without audio separately ? If so
Code:ffmpeg -i input.mov -c:v copy -an output.mov
Otherwise you're wasting time with VLC, because ffmpeg can copy the video from the original and mux your new audio in 1 step
And if you're still using VLC for this , make sure you have it COPY the stream, not encode to some other format, or it will take a longer time, and you lose quality -
Its rendfering now. I selected WAV 16bit rather than the option I was using before and the channel came up exactly as the you gave above. I think something else has gone wrong though as while I was doing that, all but one of the tracks turned grey?
What you could do is render out a selection (highlight, say 30 seconds), to use as a test with a given set of settings, and see if it works first. Then adjust your settings, maybe select better options 24bit, etc... see if that works, then go back, adjust etc... ie do a bunch of mini tests first so you don't waste time rendering the whole thing to only find out the other program doesn't like it
damm and blast I knew that grey meant some thing, sounds like just one of the surrounds was muxed.
In the channel map, a line has to be connected from the input to the output.
If you organize the tracks in the timeline in the standard order, they will already be connected in that same order automatically. That's the reason for naming the mono tracks FL, FR, etc... when they were extracted. If you left click the name of the track in the timeline, there will be an option to "move track up" or "move track down" -
From the MediaInfo, it looks like irs worked:
General
Complete name : C:\Users\Film\Documents\Audacity\k46.wav
Format : Wave
File size : 3.95 GiB
Duration : 1h 32mn
Overall bit rate mode : Constant
Overall bit rate : 6 144 Kbps
Writing application : Lavf56.1.100 (libsndfile-1.0.24)
Software : Lavf56.1.100
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 1h 32mn
Bit rate mode : Constant
Bit rate : 6 144 Kbps
Channel(s) : 8 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 3.95 GiB (100%)
But I'm not hearing speech, is that because VLC can only play in stereo? -
Yes, just make a selection in audacity
e.g let's say you want from 1min 10sec to 1min 40 sec, for a 30 sec duration clip - just left click and hold and slide over that segment you want. It will only be highlighted for the 1st track, so you use edit=>select=> in all tracks (or ctrl + shift + k) , then all 8 tracks will be selected for that 30 seconds and highlighted. Then file=>export selection , and the rest is the same
Or were you actually asking about something else ? because you mentioned "video settings" ? -
Yes video settings. Ideally I want to test a small section of video & audio, so I can see that they are in sync and hear that all the sound is there. I want to keep it in exactly the same format so that I know I can set the whole film to render without having to worry if its going to work or not.
Yes, you can stream copy a segment with ffmpeg
Code:-t is the duration in hh:mm:ss.ms -ss is the start time in hh:mm:ss.ms
Let's say you want to copy a section from 10 minutes, to 11 minutes, for a total duration of 1min
Code:ffmpeg -i input.mov -c:v copy -c:a copy -ss 00:10:00 -t 00:01:00 output.mov
Code:ffmpeg -i input.mov -map 0 -c copy -ss 00:10:00 -t 00:01:00 output.mov
But that doesn't necessarily guarentee that it's going to work. For example , what if the audio aborts at 30 minutes like in the earlier example ? But it does give you some quick & dirty feedback if something for sure doesn't workLast edited by poisondeathray; 16th Aug 2014 at 23:28.
For what it's worth, you can add multiple WAV files to a DCP-o-matic project and then map each one to the appropriate place.
Use the "Add files" button to add each WAV file. Then you can select each in turn in the file list, go to the audio tab and set which DCP channel that file should go to.
If you need any help do feel free to send email to our mailing list dcpomatic@carlh.net or direct to me (main author) carl@dcpomatic.com
DCP-o-matic's inability to use the audio channels from your original Prores file is a weakness; fixing it is on the to-do list. -
Hi Carl, nice to have you in this thread. I tried what you describe and I can't quite remember why but it didn't seem right. I think there wasn't drop down on the tracks to select left, right etc. I can't look right now as it still rendering.
I have a more pressing query now as I think I made a mistake in that our system is only 5.1 not 7.1. I actually mapped the sides (the streams in the original file were called L&R Matrix?) to the back as these last two didn't seem to be available on DCP O Matic. So 4 channels are going to 2 speakers. My concern here is that our system will refuse to play it. I thought it would just mix it internally to 5.1, but our projectionist thinks not.
Any idea if this will work or not? I'm half way through the rendering, six hours to go. I have an electrician coming to re wire my flat tomorrow morning, so only about 15 hours of rendering time left before the leccy goes off! -
Bit the bullet & stopped it, but when I went back to the sound settings, it looks like I had done it correctly as it said something like "stream will be passed unaltered to DCP channel 5/6". I've unchecked 7 & 8, and it seems like it will pick up where it left off. If there's time, I'll save the 6 channel mxf and try the 8 channel version again and we can try an ingest both and see what the projector makes of it.
Its finished rendering and it looks like the sound is ok, but while focusing on that I've made a mistake with the aspect ration. The film is scope in a 16:9 frame, I scaled the input video to scope and set the DCP container to scope. The result is the video is stretched within the scope frame. Is there an easay way (without starting again) to change the aspect ratio of the MXF? I don't think this can be done by the projector/server?
Do let me know you have trouble. -
Thanks Carl, the video makes sense of it now, all I needed to do was unselect all the audio on the video and then select each audio file in turn and map it. That really straight forward, I think I was to tired & frustrated to think clearly about it.
And after all that, we can't change the aspect ratio of the DCP with the projector, so we're having to use a DVD as a back up. But I'll know what to do next time.
Does DCP O Matic only handle up to 5.1 then?
Thanks for this great software and your help with this problem. Thanks also to poisondeathray and the others in this thread. -
[QUOTE=CarlHetherington;2341041]
My concern here is that our system will refuse to play it. I thought it would just mix it internally to 5.1, but our projectionist thinks not. -
^ (Side Channels + Rear Channels) / 2
Originally Posted by poisondeathrayLast edited by El Heggunte; 19th Aug 2014 at 13:33.
