Results 31 to 50 of 50
Please forgive if this is a stupid question...but does anyone know if there is any impact on Adobe Premiereīs Mercury playback engine? (upgrading NVidia drivers?)
The only thing that was removed was a dll which allows to access a decoder, so I doubt it has any effect on a playback engine.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
The c:\expand command finally worked but i'm still in trouble with these nvcuenc.dll-nvcuenc64.dll; i've placed them in the sys32 /sys64 folders respectively yet none of the cuda encoders work ( mediacoder/mainconcept ). I'm at a loss.I'm using the .dll from the 320.18 drivers version
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Good move by NVIDIA, this was discontinued for long time!
Developers could and should have known this was coming for a long time.
It seem to be the latest national computer pastime: people refusing to move on from outdated and obsolete software. -
I got mine to work with the Pavtube Converter by installing 64 bit nvcuenc.dll to C:\Windows\SysWOW64 and 32 bit one to C:\Windows\System32.
Next, from a command prompt as administrator I ran regsvr32 C:\Windows\System32\nvcuenc.dll. I did the same thing for SysWOW64.
This got my Pavtube Converter working and still allows me to update GeForce drivers without interfering.
Richard -
Aaaaaaaargh! So this is why on my older GTX 660 and Bandicam video encoding by CUDA works, but it won't work on my new GTX 960...!NVIDIA removed the nvcuvenc.dll file from the GeForce drivers since 340.43...
Download cuda_enc_windows7_8_64bit.zip and copy&paste the nvcuvenc.dll file to the designated folder. (C:\Windows\System32\nvcuvenc.dll and C:\Windows\SysWOW64\nvcuvenc.dll)
http://www.bandicam.com/img/forum/cuda_enc_windows7_8_64bit.zip
http://www.bandicam.com/img/forum/cuda_enc_windows7_8_32bit.zip
Thank you very much, nVidia!
...gotta test this..."I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config -
I copied the appropriate (32 bit or 64 bit) to the folder that contains the application executable. Previously, I had placed it in System32 and registered it. NVidia deleted it on the next upgrade.
When looking for dll's Windows checks the application executable folder before it checks the system32 folder. This way, NVidia will not delete the dll on the next upgrade.
gravityman -
Well, I copied the files into the System32 and SysWOW64 dirs and registred them - regsvr32 C:\Windows\SysWOW64\nvcuvenc.dll - (it somehow did not want to register the file in System32 dir) and Bandicam works just nicely. And since this is just a testing machine and I did NOT plan on drivers update, then I believe I will be fine
As lond, as Bandicam works, I'm happy
The performance while recording is not that good on GTX 960, tough. Sometimes it in BF3 drop to 51fps (recording full size, 1280x1024 @ 30fps), witch I would consider low. Maybe I should try that CPU + GPU selection, but I thought that 960 could handle it alone. My eVGA GTX 660 FTW do it rather nicely, droping in WoT recording to 41fps at worst, but since it have not a suxxking 128bit memory bus, but a 192bit one, then it might compensate well...? Dunno."I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config -
I originally put nvcuenc.dll in System32 and SysWow64, but an NVidia update deleted them. I then put them in the application executable folder. I chose 32 bit because my application was 32 bit. It works great and NVidia updates won't affect them!
Will these .dll files work on my GTX970 as the oldest drivers for the 900 series are later than the last drivers that supported CUDA. Or has the functionality been removed from the 900 series cards? (GTX950, GTX970, GTX980, GTX980Ti, Titan X).
I grabbed the zips but would like to know if it works with these cards.
EDIT: I went ahead and tested the .dll files and no dice for me. I tested by using Pavtube Bytecopy and tried a DVD rip both with and without CUDA enabled.
First of all the CUDA settings were no longer greyed out. The encode without CUDA enabled would take 0h:22m:50s and with CUDA enabled would take 0h:45m:55s. So instead of speeding up encoding, on a GTX970 it make encoding take TWICE as long.
PowerDirector 14 took the same time with CUDA on as it did with CUDA off.
And I went back to basics with DVDfab as years ago with my old 1Gb GTX550Ti, DVDfab a 1 and a half hour blu-ray rip was done in 20mins and when I tried it today it started as 45mins processing 49FPS and in 5 mins it was going to talk 3 hours and was only processing 7FPS. (On a 4Gb GTX970).
I guess that Nvidia made sure all video cards manufactured after the dumping of CUDA in the drivers had no CUDA functionality in the Hardware. (I am only guessing here).Last edited by Hoover1979; 31st Dec 2015 at 23:59. Reason: Adding more info, correcting typos
This has nothing to do with CUDA.Will these .dll files work on my GTX970 as the oldest drivers for the 900 series are later than the last drivers that supported CUDA. Or has the functionality been removed from the 900 series cards? ... I guess that Nvidia made sure all video cards manufactured after the dumping of CUDA in the drivers had no CUDA functionality in the Hardware. (I am only guessing here).
The support for the old encoder chip (nvcuenc) was removed from newer drivers, they only support the newer encoder chip (nvenc).
The best thing would have been if they kept the support active for older cards and only switch it out for newer cards, but that would have probably meant more development than they thought it was worth.
Using an application which uses the old chip (nvcuenc) with a newer card doesn't make sense since the new card doesn't have the old encoder chip.
Cu Selur
Ps.: the confusion with CUDA just happened because they first named the old encoder CUDA encoder, which was a mistake since CUDA was never involved.users currently on my ignore list: deadrats, Stears555, marcorocchini -
What about Freemake Video Converter? Is this possible to get to work old CUDA files in Windows 10 64-bit? Freemake is 32-bit.
Why are people with 900 series cards trying to use nvcuenc? nvenc is much faster, produces better quality . Some freeware GUIs that support NVEnc include staxrip ,hybrid, handbrake, NVEncC (CLI by rigaya), ffmpeg (but you have to build it yourself)
For those with older unsupported cards, try to find an older mediacoder build (maybe 3-4 years old), it supports the old encoder , but you might have to run older Nvidia drivers -
Yeah this work with this guide
"NVIDIA removed the nvcuvenc.dll file from the GeForce drivers since 340.43...
http://www.bandicam.com/img/forum/cuda_enc_windows7_8_32bit.zip" -
You can still use old Nvidia CUDA cards with freemake video converter
Step 1
manually select and download "the last" backward compatible CUDA driver from the NVIDIA website - in my case a GT9800
see - http://www.geforce.com/drivers - select manual driver search and select your video card
download and install Version 332.21 Release Date Tue Jan 07, 2014
*Includes support for applications built using CUDA 5.5 or earlier version of the CUDA Toolkit.
select cuda in freemake video converter options
Step 2
DXVA support for freemake video converter for windows XP / windows 2000
(even though freemake says it does not support DXVA in XP or Win2000- lol)
download and install the DirectX 9.0c driver from microsoft at
https://www.microsoft.com/en-au/download/details.aspx?id=34429
select DXVA in freemake video converter options
Selecting CUDA option speeds up H.264 encoding
Selecting DXVA option speeds up H.264, MPEG2, VC-1 playback in freemake application
for further info see - http://www.freemake.com/blog/cuda-dxva-easily-explained/
The auto option is definitely slower with the older video cards so use the CUDA / DXVA options instead. The freemake log files displays that both of these drivers are recognized and enabled if selected.
The ??_ extension means a .CAB archive which contains only one file
