When I create a VCD from multiple MPEG's, does it put them back-to-back, with no visible or audible gap, or does it burn them on like tracks on an audio CD?? Just wondering, because I don't want to have to make one big MPEG, because some of the files aare in different formats.
Thank you,
NuCkLeS
It will make seperate tracks for each MPEG file and it will have a 2-3sec gap between them (like an audio CD).
NERO lets you make that gap 0 sec, but I never tried it.
If you open the VCD template in NERO and drag the MPEG files into it, you will se it arranges them in alphabetical order and puts either a 2 or 3 sec gap between them. Right-click on that gap time and select PROPERTIES, and it will let you change that time to 0 sec.
Try that and see if your MPEGs play without any Audio or Video gap.
I never tried it, so let me know if it works !!
(If your MPEGs are different formats, you might have to turn OFF the VCD compliance check in NERO)~Urbs~
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
