    Aug 2014
    Phoenix
    Newbie here trying to time-bind my learning skills using Sony Movie Studio Platinum 13.
    I have 2 videos of same subject (Face shot and side shot) I want to start with Face then transition to Side shot 4 times over 2 minute video.
    I have seen posts that deal with this in Sony Vegas and need to know if my present system will allow me to do that.
    References to other posts or online articles welcome as well as any further questions about this project and my inquiry.
    Thanks in advance for taking a look at this and any help you can provide.
  2. If your're looking for multicam or some sort of automation, the Movie studio version of Vegas can't do that. But if you're looking to cut from shot to shot -- that's what it was designed for.
    Movie Studio comes with tutorials on basic editing, and there are many online.
    Aug 2014
    Phoenix
    As stated I have seen posts on using Vegas to do this but I'm looking for tutorials using my system to do this. Basic editing help files in SMS don't cover it (at least with the search terms I have used)
    But thanks for replying...
  4. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Lay out the two tracks, then use "Composite Level Envelope" on the top track to cut back and forth between tracks. "CLE" is activated via right-click on the track.
    DoubleClick on the envelope to create "Points", similar to keyframe animation. It's extremely easy.
    "CLE" varies the opacity on a scale of 0 to 100. Opacities less than 100% allow the track below to mix with the track above.
    Aug 2014
    Phoenix
    Thanks as this got me quickly into what I was looking for and now I can be one with Demille.
  6. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Right. The concept is universal, but the technicalities are expressed in different vernaculars.
