    Jul 2008
    When compressing DVDs to SL using DVD-RB (DVD Rebuilder - free) using Avisynth, and will someone in all seriousness take a look at both INI files and please let me know if there should be anything to change like a better deinterlacing than decomb521 or if anything should be removed or anything at all? I know both INI files do work.
    Rebuilder.ini:
    [Options]
    vts_min_size=0
    SkinVersion=3
    QuEncHQ=1
    HC_Quality=2
    HC=HC.ini
    HCTargetSectors=2260000
    ReduceOpt=0
    CCETargetSectors=2260000
    RemoveDTS=1
    OneClick=0
    Mode=5
    HalfD1=0
    Convert_16_9=0
    DisableInterlace=0
    LogFile=1
    AdditionalOutput=1
    Completed=122
    idct7Opt=1
    ConvertToYUY2=0
    Reminder=120
    AVSFilter01=
    AVSFilter02=
    [Audio]
    Selected=
    [Subpictures]
    Selected=
    [Paths]
    DECOMB=C:\Program Files\AviSynth 2.5\plugins\Decomb.dll
    HC=C:\DVDRebuilder\HCenc_026.exe
    FFMPEG=C:\Program Files\FFmpeg\ffmpeg.exe
    MPEG2DEC=C:\DVDRebuilder\DGDecode.dll
    QuEnc=C:\DVDRebuilder\QuEnc\QuEnc.exe
    REJIG=C:\DVDRebuilder\ReJig\ReJig.exe
    NICAUDIO=C:\Program Files\AviSynth 2.5\plugins\nicaudio.dll
    Source=L:\DVD\MOVIE\VIDEO_TS\
    Working=L:\TEMP\
    Output=V:\DVD\MOVIE\
    [CCEOptions]
    VBR_bias=25
    Quality_prec=16
    eclPasses=2
    HC.ini:
    *BITRATE 8000
    *MAXBITRATE 9599
    *PROFILE BEST
    *AUTOGOP 18
    *DC_PREC 8
    *PROGRESSIVE
    *MATRIX   mpeg
    *LUMGAIN 1
    *BIAS 0
    *ASPECT 16:9
    *PRIORITY HIGH
    *AVSRELOAD
    May 2003
    Peterborough, England
    Why are you deinterlacing if the target format is DVD? I'd just use DVDShrink personally......
    Sep 2006
    No need to interlace for dvd output. IIRC decomb is for interlaced footage. In any case you can do this for film sources by turning the video back into progressive. This can potentially save some space from what I recall but it was not worth it in most cases.
