  1. Best PotPlayer setup?
    Like what are the best filters for it?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Test the default install.
    Google is your Friend
    Feb 2014
    QUÉBEC
    for me it's madvr for rendering, CoreAVC for decoding and LAV Filters for audio .
    but it's only my opinion
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    "Quality" will vary based on your hardware, use, and opinion.
    If you are happy with the default install, no reason to tinker about and muck something up. If you have a more specific question (ie: you are seeing a specific problem) or observation after testing, then feel free to comment.
    As with anything else, you will get numerous opinions for what is "best". But if you have no basis for comparison, you will never know if they are better or not.
