Results 1 to 9 of 9
  1. I have PC with windows 2000 and Software decoing DVD drive. Please let me know which one is the best DVD software to play DVD discs on DVD rom drive.
    Thanks in advance
  2. The two best Software DVD Players i've come across: PowerDVD / WinDVD
    personaly I use PowerDVD, but i'm sure others will vote for WinDVD, so i'm giving you both
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. thanks to you Sefy, I have now got powerdvd installed and running I would recommend it.
    joem
  4. I have Power DVD 3, does anyone know if there is a hack/patch to enable you to change the region more than 5 times - it's really annoying!
    Any advice would be graetly appreciated.
  5. Get Region Killer, so far it's the best program i've seen for eliminating the region change problems!
    You can download it from the CloneCD homepage, it's the same guys who made it that made CloneCD
    Best Regards,
    Sefy Levy,
  6. Thanks Sefy, I think the problem lies with my hardware (LG DR 8160B) I presume region killer only solves software issues? I have tried DVD genie and that didn't work.
  7. Well, if your DVD drive itself has been locked, you can try finding a region free firmware, and that will fix that issue.
    But usually the Software part is also a trouble, and you should use something like DVD Genie, I just recommand Region Killer more, it's easier to use.
    Best Regards,
    Sefy Levy,
  8. Thanks for the advice, i'm searching for some firmware now - do you know any good sites?
  9. Yes, but contact me in email for that, I don't publish warez/cracks on the forums, sorry!
    Best Regards,
    Sefy Levy,
