  1. Hi if you are using an android phone, you can download an app called Vidmate. Search in google and you will find its official site quickly. This app can download highlights, videos from starsports, espn cricket in high quality. It's easy to use. Highly recommend.
  2. Member WazaKrash's Avatar
    Jan 2015
    in Europe
    Hello,
    the method of Akshay seems good.
    Moreover, another person have the same request as you, it was here :
    https://forum.videohelp.com/threads/285567-How-to-capture-record-streaming-video/page5
    Originally Posted by sscomp32 View Post
    Hi Guys anybody can help download videos from starsports.com:
    sample video:
    http://www.starsports.com/cricket/video/vod/videoid=1378806/index.html#tri-series-aust...-why-white-why
    Jan 2015
    India
    ^^ I can download the hockey video without any problem using IDM. The problem is downloading the cricket video.
    livestreamer "hlsvariant://https://staruvod1-vh.akamaihd.net/i/vod/ausvsindia2014/matches/23_01_2015/635576351697733718_,54,106,180,400,800,1300,2000,_STAR.mp4.csmil/master.m3u8" best -o video.ts
    Hi I found a way to download this video . All you need is the "hdnea=st=...........~exp=.............~acl=/*~hmac=........................&hdcore=2.11.3&g=.. ............." part of the URL to put after the master.m3u8 which is different for every run.
    So the code in post quoted becomes
    livestreamer "hlsvariant://https://staruvod1-vh.akamaihd.net/i/vod/ausvsindia2014/matches/23_01_2015/635576351697733718_,54,106,180,400,800,1300,2000,_STAR.mp4.csmil/master.m3u8?hdnea=st=...........~exp=.............~acl=/*~hmac=........................&hdcore=2.11.3&g=..............." best -o video.ts
    now run this and the video will start downloading.
  4. @sscomp32
    it is also a good forum here
