Was not sure if I should post here or in the Video Conversion thread. Since the end result I want is a DVD I thought this was the proper place. Feel free to move it, if it is posted incorrectly.
I have a .mkv file I am trying to convert to a DVD 5. I set up AVStoDVD (2.7.3). Click on start. HCenc pops up. After a few seconds I get the following messages in the info line.
ERROR, can't process AVS file. Wait for Avisynth error message
ERROR, FFVideoSource Video codec not found
Here is the MediaInfo
General
Unique ID : 213375677756625703266881381034577752670 (0xA086A924EA73175AA88B38E04E0DF25E)
Complete name : E:\Video-Needs to be conveted\dww.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 5.51 GiB
Duration : 3h 53mn
Overall bit rate : 3 376 Kbps
Movie name : Balla Coi Lupi - Special Edition <ZMachine>
Encoded date : UTC 2014-05-15 18:20:43
Writing application : mkvmerge v6.9.1 ('Blue Panther') 64bit built on Apr 18 2014 18:23:38
Writing library : libebml v1.3.0 + libmatroska v1.4.1
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Codec ID : V_MPEGH/ISO/HEVC
Duration : 3h 53mn
Bit rate : 2 413 Kbps
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Bits/(Pixel*Frame) : 0.064
Stream size : 3.94 GiB (71%)
Title : Video H.265 (Encoded by ZMachine)
Default : Yes
Forced : Yes
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 3h 53mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 749 MiB (13%)
Title : Audio AC3
Language : Italian
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 3h 53mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Title : Audio AC3
Language : English
Default : No
Forced : No
Text #1
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Title : Sub Forced
Language : Italian
Default : Yes
Forced : Yes
Text #2
Format : ASS
Title : Sub Forced
Language : English
Default : No
Forced : No
Text #3
Format : ASS
Title : Sub
Language : Italian
Default : No
Forced : No
Text #4
Format : ASS
Title : Sub
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : Main Title; a Wounded Man
00:05:01.050 : St. David's Field, Tennessee
00:11:46.664 : Fort Hayes
00:20:19.760 : Journey to the Furthermost Outpost
00:26:41.349 : Clean-Up Duty
00:36:10.167 : The Ruthless Pawnee
00:42:19.620 : Contact with the Sioux
00:47:22.381 : Riding Out to the Indians
00:52:50.625 : Meeting with the White Man
00:56:54.035 : Stands with a Fist (Christine)
01:03:57.208 : Invited to the Village
01:09:49.351 : The Buffalo Return
01:11:47.594 : The Hunt
01:19:58.960 : A Good Trade
01:25:33.753 : Dances with Wolves
01:32:32.922 : Bestowed a Great Honor
01:41:53.065 : Falling in Love
01:53:44.234 : Attack of the Pawnee
01:56:17.261 : Told to Mourn No More
02:04:32.047 : Like the Stars
02:13:04.226 : Retrieving the Journal
02:18:54.117 : Do You Salute Him or Shoot Him?
02:27:34.846 : A Little Help From Friends
02:38:09.104 : Leaving for the Good of the Tribe
02:42:20.814 : End Credits
02:53:02.330 : Permission to Love
03:03:59.695 : The Most Important Trail
03:13:15.709 : "Turned Injun, Didn'cha?"
03:20:56.044 : Traitor Status
03:27:34.066 : Wolves and Other Animals
03:35:37.341 : Parting Gifts
03:48:25.316 : Epilogue/Credits
Here is the info from the log file.
<8/11/2014 5:56:40 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: DWW
DVD Menu: No Menu
Output Folder: E:\Video-ISO
Delete Temp Assets Files: Yes
Delete Temp Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Video Source Filter: A2DSource
AVS Audio Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
Frame Adjust Strategy: 1
PAL SpeedUp: 0
Video Resolution: 0
Video BitRate Min: 2000
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 16pt (255,255,255)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: D: HL-DT-ST BDDVDRW CT21N 1.00
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Unload ActiveMovie library: 0
Adjust ffdshow at runtime: 1
Save General Settings: 0
TITLE 1 SOURCE FILES
Video: E:\Video-Needs to be conveted\dww.mkv
Info: V_MPEGH/ISO/HEVC - 2413 kbps - 1920x816 - DAR 2.353 - 23.976 fps (CFR) - 3:53:49 hours - 336367 frames
Audio 1: E:\Video-Needs to be conveted\dww.mkv
Info: AC3 - 448 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 3:53:49 hours (0 ms delay) - EN
Subs 1: E:\Video-Needs to be conveted\dww.mkv
Info: Advanced SubStation (ASS) - Sub Forced - EN
Subs 2: E:\Video-Needs to be conveted\dww.mkv
Info: Advanced SubStation (ASS) - Sub - EN
[MediaInfoLib - v0.7.61]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
LoadPlugin("C:\Program Files (x86)\AVStoDVD\Lib\ffms2.dll")
Video = A2DVideoSource("E:\Video-Needs to be conveted\dww.mkv", CacheFolder="C:\Users\Richard\AppData\Local\Temp", FrameRate=23.976, VFR=false)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
# Forced 'FFAudioSource' to encode secondary Audio Tracks
Audio = FFAudioSource("E:\Video-Needs to be conveted\dww.mkv", track=2, cachefile="C:\Users\Richard\AppData\Local\Temp\A2D FFA_" + String(Rand()) + ".cache")
Video = Video.ConvertToYV12()
Video = Video.AddBorders(0,130,0,132)
Video = Video.Spline16Resize(720,480)
#Using DGPulldown/HCenc to upsize FPS
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 3455.2 MB
Encoding Parameters: -ini "C:\Users\Richard\AppData\Local\Temp\DWW_0_dww.HCe nc.ini"
HCenc ini file:
*INFILE C:\Users\Richard\AppData\Local\Temp\DWW_0_dww_1.av s
*AVSRELOAD
*OUTFILE C:\Users\Richard\Videos\DWW_0_dww.m2v
*LOGFILE C:\Users\Richard\AppData\Local\Temp\DWW_0_dww.HCen c.log
*MAXBITRATE 9000
*BITRATE 2066
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 20
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*DBPATH C:\Users\Richard\AppData\Local\Temp
*WAIT 2
<8/11/2014 5:57:17 PM>
Process aborted during Title 1 VIDEO encoding operations.
For Video issues troubleshooting see Help/FAQ/Video section.
Log file created by AVStoDVD Release 2.7.3
Thanks in Advance,
Richard
Hi Richard,
I fear that FFMpegSource does not handle correctly HEVC video format. You should look for a directshow codecs suite that support HEVC (i.e. LAV Filters), install it, then retry with the conversion.
Bye
