Hi,
I want to play a file with DTS HD Master Audio. If I play it with MPC-HC and look up audiostream, then there is 48.000 kHz. How do I play it with 96.000kHz?
MediaInfo Lite 0.7.69 tells me that it has a sample rate of 96.000 kHz / 48.000 kHz:
General
Complete name : hd_dts_living_world_of_audio_v1_lossless-DWEU.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 189 MiB
Duration : 49s 720ms
Overall bit rate : 32.0 Mbps
Maximum Overall bit rate : 46.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=10
Codec ID : 27
Duration : 49s 49ms
Bit rate mode : Variable
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Audio
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Muxing mode : Stream extension
Codec ID : 134
Duration : 49s 40ms
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 8 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 96.0 KHz / 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Q: Can LAV Audio decode DTS-HD?
A: Kind of. On its own, it cannot. But, LAV Audio supports using the ArcSoft DTS decoder, which allows decoding of full DTS-HD.
Just drop the "dtsdecoderdll.dll" from the TMT3/5 Codecs directory into LAV Audio's directory, and enjoy. NOTE: This only works on 32-bit! -
Thanks. So only the "Core" of DTS-HD MA is supported by LAV Filters itself?
My HTPC connected to an AV-Receiver (with support of all the formats like DTS-HD MA, TrueHD, ...): I think the best way is to use bitstreaming.
Has ffdshow full support of DTS-HD MA?
Where do I get the file?
