Results 1 to 13 of 13
  1. Recorded a large AVI (42GB) file using my HD WebCam, now i cannot open it!
    It was an important family event, and i cannot open the file or do anything with it. Tried opening it with Adobe Premier, Gspot, Windows Player, Quicktime Player, nothing...
    PLEASE HELP!
  2. Try VLC, ffplay
    If you open up in a hex editor, is there any data ? If it's all zero's, the file is useless
  3. i used HxD to open it. its not all zeros. ffplay is pretty confusing, what should i do with it?... VLC doesn't open the file.
  4. Just drag & drop the file on ffplay.exe or use ffplay -i input.avi . It can play basically anything that's not broken or encrypted
    Does your camera have to "finalize" files ? Or does it come with software to "finalize" files? check your manual . Or have you recorded with this webcam before, and the AVI's were functional right after recording ?
  5. Member Cornucopia's Avatar
    Model #?
    Have you tried MediaInfo?
  6. Try VirtualDub or VirtualDubMod. If they find problems they should let you know. If one of them can open it, resave it as a new AVI after selecting "direct stream copy" as the video compression method, assuming you don't want to re-encode the video in the process.
    You could also try the same thing with AVIMux-GUI. It'll just remux the AVI (it doesn't re-encode).
  7. Originally Posted by Cornucopia View Post
    Model #?
    General
    Complete name : F:\@capture projects\Clip 9.avi
    Format : AVI
    File size : 40.3 GiB
    Duration : 10ms
    Overall bit rate : 34 596 Gbps
    Video
    Format : JPEG
    Codec ID : MJPG
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 24.000 fps
    Color space : YUV
    Compression mode : Lossy
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Duration : 10ms
    Bit rate mode : Constant
    Bit rate : 1 411.2 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Bit depth : 16 bits
    Stream size : 1.72 KiB (0%)
    Alignment : Aligned on interleaves
  8. Originally Posted by poisondeathray View Post
    I put the record on, then walked away, i think at some point the capture software crashed from the size of the file.
  9. "Duration : 10ms" Doesn't that mean that there is nothing there?
    Extraordinary claims require extraordinary evidence -Carl Sagan
  10. Originally Posted by TreeTops View Post
    one would think so...
    i played it by dropping the file onto the FFPLAY...there was a lot of static, and then my voice would cut in periodically...
  11. if i could extract all audio from it at least, that would be great, even if lossy...i could then just clean up in audition and use the information from the audio...
  12. here is the
  13. here is what i discovered, while playing the file in FFPLAY, the static noise is interrupted by a clear 1-second recording of my voice (all different content) EVERY 13 seconds...
