I've extrated a DAT file off a VCD & now need to convert it to a format that VCDEASY can recognise to burn. Can anyone help?
look left...how to...convert...
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
I use a software called VCDCutter to convert DAT to VCD... I found it in Internet.
I know there is more softwares that is able to do it, but I cant remember right now (I am at work)
I can send you (to your private email) the link to software, when come home, if you want... Just ask.
Fredİ -
I've tried VCDGEAR but the MPG won't burn in VCDEASY. I've used TMPGE to convert AVI but I'm unsure if I need to follow the same method to convert the dat file. -
http://www.vcdgear.com/ is the way to go for dat to mpg
then burn the mpg to vcdyour pal,
Stinky -
have you tryed to simply drag the file into NERO ?
fOR NERO MAKES NO DIFFERENCE THE EXTENSION OF THE FILE : HE WILL ANALYZE FILE AND TELL YOU IF IT'S VCD COMPLIANT OR NOT.
NOT SURE IS THE SAME FOR VCDEasy.
ANYWAY YOU CAN DIRECTLY RENAME EXTENSION FROM .DAT INTO .MPG AND THIS SHOULD BE ENOUGH
errata corrige : it's not enough for vcdeasy to rename .dat in .mpg but dooing so and trying to burn,vcdeasy help you and says what you have to do to obtain a correct file !
REGARDS
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 10:25 -
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 17:06 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42
