Hi ,
I have an mkv
0.2 is hindi audio.Code:ffmpeg\ffmpeg-20131202-git-e3d7a39-win32-static\bin\ffmpeg .exe -i "c:\1.mkv" ffmpeg version N-58699-ge3d7a39 Copyright (c) 2000-2013 the FFmpeg developers built on Dec 1 2013 22:01:48 with gcc 4.8.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp eex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aa cenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavp ack --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib libavutil 52. 56.100 / 52. 56.100 libavcodec 55. 44.100 / 55. 44.100 libavformat 55. 22.100 / 55. 22.100 libavdevice 55. 5.102 / 55. 5.102 libavfilter 3. 91.100 / 3. 91.100 libswscale 2. 5.101 / 2. 5.101 libswresample 0. 17.104 / 0. 17.104 libpostproc 52. 3.100 / 52. 3.100 Input #0, matroska,webm, from 'c:\1.mkv': Metadata: creation_time : 2011-05-25 18:29:43 Duration: 01:32:09.58, start: 0.000000, bitrate: 2380 kb/s Stream #0:0: Video: h264 (Main), yuv420p, 1280x544 [SAR 1:1 DAR 40:17], 23.9 8 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Stream #0:1: Audio: aac, 48000 Hz, 5.1, fltp (default) Stream #0:2: Audio: mp3, 48000 Hz, stereo, s16p, 224 kb/s Stream #0:3: Subtitle: subrip (default) Stream #0:4: Subtitle: subrip At least one output file must be specified
My samsung TV plays mp4 properly . In mkv , it does not support fast forward & no way to switch audio tracks .
So I tried to convert to mp4 using ffmpeg binary in windows . The resulting mp4 has audio being heard before concerned video frame appears . What should I do ?
sorry for my late reply . turns out mp4 plays properly on desktop . But my LCD tv causes sync issue for this video . converting to vob will blow up file size . can you suggest any alternative ?
