I can burn DVD's using MovieFactory with no problem on the DVD 104 (once the autorun had been disengaged). However, I can't burn SVCD's onto CD's through the this software.
AT 'initialising disk' the system hangs with just the busy light on the DVD burner remaining on. It appears that MovieFactory doesn't actually recognise the 104 as a CD burner as well as DVD - at least that's my guess
I have no problem using my HP9710 burning SVCD through MovieFactory.
Any thoughts?
GRC
Hi,
Yup. I took off the Adaptec software (EasyCD etc) but it wouldn't uninstall fully (something wrong with the uninstaller). Put on Nero 5.8.8.0 - same problem.
Took the 104 to a friend who has exactly the same set up but with the AO3 but has never used the Adaptec software - no problems. Burns CDs well.
Something is getting left behind with the Adptec sofware that is preventing the 104 burning CDs.
REgards
GRC
GRC -
Nero and Adaptec both install their own low level suffs,
and they can't live with each other.
I installed them on disk in pull out drawer to seperate them.
But if you have Nero, why bother with adaptec ? -
Nero does not trash the system. EZCD does, that why he's better off running force aspi or using a later build of Nero, like 5.5.7.8 or 5.5.8.0.
Ulead DVD MovieFactory 6 Plus Menu Option Question
By SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 14:42 -
Ulead DVD Moviefactory 6 Plus (trying to get to grips after UDVDWorkshop2)
By dvdfever in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2009, 21:01 -
Joining in Ulead DVD MovieFactory - does it lead to worse quality?
By rosbif08 in forum EditingReplies: 2Last Post: 6th Aug 2008, 22:32 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 11:43 -
Questions about Ulead DVD MovieFactory 6
By cheeseandcrackers in forum Authoring (DVD)Replies: 5Last Post: 18th Jun 2007, 11:46
