It's possible the answer to the question (in bold) below is "no", but...
I had a video (25 FPS, see below) that was 1h13m while the video was 1h7m. Converting the audio to wav and stretching it did the trick. Somehow the audio had become sped up and there was no way to go back to the source and get a new copy. It's this xvid/avi file or nothing.
Now this adds a few conversion steps to the process so I was wondering: Would there have been a way to do this without re-encoding the audio?
File Name .........................................: TdL (1947).avi
File Size (in bytes) ............................: 1,563,989,018 bytes
Runtime ............................................: 1:13:45
Video Codec ...................................: XviD ISO MPEG-4
Frame Size ......................................: 720x576 (AR: 1.333)
FPS .................................................: 25.000
Video Bitrate ...................................: 2441 kb/s
Bits per Pixel ...................................: 0.235 bpp
B-VOP, N-VOP, QPel, GMC.............: [B-VOP], [], [], []
Audio Codec ...................................: 0x2000 (Dolby AC3) AC3
Sample Rate ...................................: 48000 Hz
Audio Bitrate ...................................: 384 kb/s [2 channel(s)] CBR
No. of audio streams .......................: 1
Results 1 to 12 of 12
This is nøt å signåture.™
For playback, you can use the audio "stretch by" option in MKVToolNix if you re-wrap in an mkv container. But the quality usually isn't the best since it's done on the fly in realtime, you can get crackles
Some containers, like MVK, let you specify a stretch/shrink factor for the audio. Unfortunately, not all players will obey the flag.
It's either re-encode the audio or change the frame rate. Try opening the AVI with VirtualDub. It has an option to change the frame rate to match the audio duration. That may do the trick, or you may need to adjust it manually until it's right. Once you're done, save it as a new AVI after selecting "direct stream copy" as the video compression method under the Video menu (no re-encoding). The audio should default to direct stream copy.
+1 for MKVToolNix. You can add a delay to it to bring it back into sync and it just puts it back into another .mkv container.
Sorry. I must have missed that post.
I'd be re-encoding the audio. Yes, you can stretch it with MKVMergeGUI if you don't mind remuxing it as an MKV but it tends to make decoding it properly (no pops or crackles) a bit hit and miss if it's stretched by anything other than a very small amount. Better to stretch it while re-encoding, even if in theory there is some quality loss. -
Thanks for the input. Seems to be just as I feared. Well, there is some re-encoding that shouldn't have been necessary, but the damage is minimal.
