  1. Hi,
    I try to convert some TV Shows with handbrake. I did a lot of conversation with handbrake. But with 2 Shows I have a problem.
    The first one is a recording from TV in h.264. After converting this Video with handbrake it Looks to dark and blocky.
    I attached 2 screenshots and here is the Input and Output:
    Input
    General
    Unique ID : 238254484877995024199196247523555667434 (0xB33E2509D235FE459E955A35C251EDEA)
    Complete name : \\wks-s-02\d$\CutPlace\3.MKV\x.mkv
    Format : Matroska
    Format version : Version 4 / Version 2
    File size : 3.86 GiB
    Duration : 50mn 12s
    Overall bit rate : 11.0 Mbps
    Encoded date : UTC 2014-08-03 13:22:26
    Writing application : mkvmerge v7.1.0 ('Good Love') 64bit built on Jul 27 2014 13:06:55
    Writing library : libebml v1.3.0 + libmatroska v1.4.1
    DURATION : 00:50:12.864000000
    NUMBER_OF_FRAMES : 125536
    NUMBER_OF_BYTES : 72308736
    _STATISTICS_WRITING_APP : mkvmerge v7.1.0 ('Good Love') 64bit built on Jul 27 2014 13:06:55
    _STATISTICS_WRITING_DATE_UTC : 2014-08-03 13:22:26
    _STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Video
    Format : AVC
    Format profile : High@L3.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=4, N=16
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 50mn 12s
    Bit rate : 9 749 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 50.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.212
    Stream size : 3.42 GiB (89%)
    Default : Yes
    Forced : No
    Output
    General
    Unique ID : 180613526029589024869493843700121791834 (0x87E0E65A38C5A875FF66A9C1DAC6ED5A)
    Complete name : \\wks-s-02\d$\CutPlace\4.Done\x.mkv
    Format : Matroska
    Format version : Version 2
    File size : 1.01 GiB
    Duration : 50mn 12s
    Overall bit rate : 2 878 Kbps
    Writing application : HandBrake 0.9.9
    Writing library : libmkv 0.6.5
    Video
    Format : AVC
    Format profile : Main@L4.0
    Bit rate : 2 373 Kbps
    Height : 720 pixels
    Frame rate mode : Variable
    Color space : YUV
    Bit depth : 8 bits
    Writing library : x264 core 130 r2273 b3065e6
    Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=500 / keyint_min=50 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Maybe someone has an idea how to fix this. I also have this for one SD TV Show (Star Wars The Clone Wars).
    thx in advance
    Bjoern
    Image Attached Images
  2. Hm,
    just for Info - it just Looks this way when playing it in WMP 12.
    It doesn't look this way on LG TV (Streamed from Plex) or Media Portal 1.8 with LavCodec.
    cu
    Walzing
  3. WMP 12 with Lavcodec seems to work fine.
    So it has to be a Problem with Microsoft Decoder
