  1. How do I add small borders on my movies, I cant see a way to do it in TMPGEnc.
    Thanks in advance
  2. Originally Posted by chodges84
    Thanks in advance
    Indeed you can!
    Choose Setting for your template, under the tab Advanced you choose the option Clip frame. With the Clip frame toggle-down and the option box for Top mask/Bottom mask set the size of the top and bottom border using the corresponding 'spinners'...
    HTH
    "The future is no longer what it used to be"
  3. Cheers, U da mAn
    Need a coach for anything? Try George Youngs Coaches here for the best service at the lowest prices: http://www.carlberry.co.uk/rfnshowo.asp?O=YOUNG
