the bottom of the videos are cut off why is this
Results 1 to 11 of 11
Not likely. You sure it's not your VHS deck -- head switching noise at the bottom of the frame?
nope because i tested the vhs player and same tape on another capture card and its fine but its really old so i cant use it with windows 7 and the pc that its on is too slow to capture video
check the pic half the video is cut off
is the easy cap ntsc only ??? or something could this be why it cuts off half the video because the vhs player i use is palLast edited by jamespoo; 4th Aug 2014 at 02:44.
Your software should have a PAL ie 720*576 setting.
But I see you are using Win7 so you may have a cheap rip-off easycap with suspect drivers.
