I'm using this script in avisynth:
The thing is, I don't know how to actually edit the MP2 Audio. I'm encoding with x264, so that takes care of the video. Should I use something different to edit the audio?Code:SetMTMode(5, 4) SetMemoryMax(1600) loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins\DGAVCDecode.dll") A= DirectShowSource("audio PID 1100 L2 2ch 48 192 DELAY -3ms.mp2", video=false) V= AvcSource(video.dga") AudioDub(V, A) Trim(639,15946) + Trim(20972,29961)
I figured out a good way to do this. If you're wondering, I decided to open the script in virtualdub and save the audio as a WAV, then use nero to encode it to AAC.
You could also open script in Virtualdub, do any editing if necessary and then use the external encoder feature to save as aac.mp4.
Encoder Set:
MP4 Medium
Video encoder: x264 Medium
Audio encoder: neroaac
Multiplexer: mp4box
File description: mp4box
File extension: mp4box
Encoders:
x264 Medium:
Type: Video encoder
Program: C:\Tools\x264.exe
Command argument: --crf 17 --preset medium --tune film --demuxer raw --input-csp i420 --input-res %(width)x%(height) --fps %(fpsnum)/%(fpsden) -o "%(tempvideofile)" -
Output parameters: %(outputname).264
Launch parameters:
x Interpret non zero return code as error
x Redirect standard output to log
x Redirect standard error to log
neroaac
Type: Audio encoder
Program: C:\Tools\neroAacEnc.exe
Command argument: -q 0.45 -ignorelength -if - -of "%(tempaudiofile)"
Output parameters: %(outputname).aac
Launch parameters:
Audio Tab:
Input format: WAV file
Compression: Bypass compression
mp4box:
Type: Multiplexer
Program: C:\Tools\MP4Box\MP4Box.exe
Command argument: -add "%(tempvideofile)" -add "%(tempaudiofile)" "%(outputname)" -fps %(fps)
Output parameters:
Launch parameters:
x Delete output file before starting
or...
Here is my most resent encoder set vdprof file. It has most encoder sets that you would ever use. Change the .txt extension to .vdprof and place in C:\Tools\VDPROF folder. Open Virtualdub and under Options, choose External encoders, choose import and select the .vdprof file.
Most of my CLI encoders are in my C:\Tools folder unless they depend on other files. You'll need to either find and download all the CLI encoders or you could download Selur's Hybrid program that has then all in one folder. You'll need to redirect the external encoder to wherever you have the CLI encoders.
It seems like a lot of work but once you have them set up, just choose File > Export > Using external encoder > choose appropriate encoder > Save as > Save. -
MeGUI has an "AVS Cutter" under the Tools menu. It basically just adds "Trim()" or multiple trims to a script as you've already done. It'll also save a "cuts file" which can be loaded into MeGUI's audio section and the audio will then be re-encoded to match the video.
Alternatively, MeGUI has an audio cutter under the Tools menu. It'll load the same "cuts file" and split and rejoin the audio to match the video without re-encoding it, if you'd prefer not to.
MeGUI's audio cutter uses BeSplit to do the work. You could probably split and rejoin the audio yourself via a commandline but that'd involve converting Trim() to timecodes, I'd imagine.... I just let MeGUI do it.
