I took interview video for a CEO yesterday. The picture and lighting were good but the audio recording was bad. It's like the audio input level was a bit higher/over. I use Adobe Premiere Elements 12 to edit my video but no luck to fix the audio track. I tuned down the audio gain a bit but it doesn't work, still deteriorating . Any software can help me to fix this audio problem ? I can call the CEO back to shoot another video.
				Results 1 to 14 of 14
	You'll have to post a sample for anyone to give any advice. Generically, try Audacity.
	If you already use Premiere Elements, just export the audio track from there to a WAV (or high quality mp3, to keep the filesize down).
	Sorry, couldn't find the audio exporting feature in Adobe Premiere Elements 11, can you elaborate ?
	I don't have the product, but I found this on the internets.
 http://help.adobe.com/en_US/premiereelements/using/WS09e4b3c48f3a79fc19b622510385d4355...9-3AC7D6FF292E
	According the the uploaded sample, only the left channel is distorted. If that is true for the entire file, then you can just remove the left channel and fill the empty left channel with the right channel. I do not know if this is possible in Premiere Elements, but it is in the full blown version of Premiere.
 Brainiac
	I do not use Audacity but this YouTube video may help:
 https://www.youtube.com/watch?v=mlKX6p85R2M
 It's from 2008 but concept should be the same.
 Brainiac
	Load the audio into Audacity
 Use the little triangle in the left side of the screen (next to Ken Talk)
 Select Split Stereo Track
 Highlight the bad track by double clicking
 Tracks -> Remove Tracks
 Tracks -> Add New -> Audio tracks
 Highlight the track with audio by double clicking. Edit -> Copy
 Highlight the track without audio. Edit -> Paste
 The little triangle again -> Make Stereo Track
 File -> Export
 (In case you don't already have you'll probably want to install Lame/FFmpeg)
 I don't use Adobe Premiere Element but I would think you could do something similar there.
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
