I am trying to learn how to softsub a video, author those subs to the video, and finally burn that subbed video to a DVD. The video is in a foreign language, and I've searched everywhere for a purchaseable version with English subtitles...however I had no luck. So instead a friend of mine had a HD backup copy with just the Chinese subtitles. I was able to find sites that hosted the videos with subtitles online, so I was able to make the subs using Subtitle Workshop. However, since I know nothing besides how to make the subtitles on Subtitle Workshop, I don't know what steps will next be necessary to put these in DVD format. This is some of the info regarding the video below.
General
Unique ID : 211289636576849422114322885933520167901 (0x9EF4E75F94D0E80D8F120AC731B8A3DD)
Complete name : C:\Users\Sarah\Videos\Absolute Boyfriend 01-19 720p Complete\Absolute.Boyfriend.E01.720p.HDTV.x264.AAC-JOMA.mkv
Format : Matroska
Format version : Version 1
File size : 1.21 GiB
Duration : 43mn 11s
Overall bit rate : 4 003 Kbps
Encoded date : UTC 2012-08-09 14:08:17
Writing application : mkvmerge v2.6.0 ('Kelly watch the Stars') built on Mar 24 2009 15:23:17
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 9 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 43mn 11s
Nominal bit rate : 3 695 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.134
Writing library : x264 core 116 r2074 2641b9e
Encoding settings : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3695 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / ip_ratio=1.60 / aq=1:1.00
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : HE-AAC / LC
Codec ID : A_AAC
Duration : 43mn 11s
Channel(s) : 2 channels
Sampling rate : 96.0 KHz / 48.0 KHz
Compression mode : Lossy
Language : Chinese
Default : Yes
Forced : No
Based off of all the information regarding this video, what all will I need to do to softsub the video onto a DVD? What programs should I use for each of these steps?Any feedback would be great since I am fairly new to all of this...
			Closed Thread
	AvsToDVD can do it all. If you want a fancy menu then it may get a bit more complex.
 It seems to be available with subs:
 http://www.amazon.com/Absolute-Boyfriend-Kareshi-Japanese-English/dp/B003KQXJ0E
	Yep. Just buy it. Reread our rules.
 https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)?
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
