Results 1 to 11 of 11
  1. I'm using Avisynth with MeGUI 2507. It seems to encode normal length videos fine such as 1-3 hour long videos. However the 24 hours or Le Man (21 hours long after commercials removed) has a 61 second delay in the audio after the MeGUI encoding yet it definitely wasn't in the source because I use a program that makes sure there would be no delay if the video were to be demuxed. My source was MKV and I set MeGUI to encode to a M2TS as I'm hoping that will retain the x264 switches I set.
    I can't see anything in the log which would suggest why the delay occurred.
    Is there anything I can do in MeGUI to prevent a delay occurring? Would encoding (in MeGUI) to a different container help?
    Is there any way in MeGUI to only encode to a .h264 file and NOT into a container?
    The source video is fine. It's 1080i 25fps TV footage. I tested it myself by demuxing the source MKV with DGIndexNV and TSMuxer. When I muxed back with TSMuxer there was no delay so it's something MeGUI is doing. I set MeGUI to use DGDecodeNV to index the file.
  2. Originally Posted by VideoFanatic View Post
    file format => rawavc
    Are you doing this for BD ?
    --keyint 500 --ref 9
    That is a problem. Won't affect sync or delay, but will make it not compatible
    --ref 6 --keyint 100 if you are using 2sec GOP rules
    Le Mans 24 Hour 2014 Race - [0] English Delay 65571ms.ac3
    Is that the file you got from DGNVTools ? The delay is usually written into the name
  3. 61seconds seems kind of huge, are you sure the source is okay?
    With 24hrs+ I would also in general recommend so split the content, since some tools might run into overflows.
  4. Where is file format => rawavc? I'm using MeGUI 2507
    Yes the file will be for Bluray. I'm using all the Bluray compatible settings (as it actually lowers the file size slightly) apart from the KeyInt of 50 which I didn't want to use as it increases the file size. The video still plays in Bluray players even though it's not 100% compliant. Didn't realize MeGUI uses a KeyInt of 500. I was told by the author of Simple x264 Launcher that the x264 codec default is 250 unless you specify one which I didn't?
    Splitting files is a nightmare. Don't want to do it. Yes the source is fine. It's 1080i 25fps TV footage. I tested it myself by demuxing the source MKV with DGIndexNV and TSMuxer. When I muxed back with TSMuxer there was no delay so it's something MeGUI is doing. I set MeGUI to use DGDecodeNV to index the file and to encode to M2TS.
  5. Originally Posted by VideoFanatic View Post
    It's on the front of the GUI, input tab. 4th from the top drop down menu, right under encoder settings
    It might be set to 10x fps in megui. In the advanced settings, there is a "GOP calculation" FPS based setting
    Yes, many players can play non compliant files. But a --keyint of 500 will usually exhibit seek problems in many BD players. Try navigation FF/RW then see if you change your mind.
    But on a source like car racing, you might not see the difference or detect the seek problems - because the actual keyframe placement might be a lot shorter. The reason is with scenecut active, a new keyframe will usually be placed as the camera switches. Car races are usually fast paced, multiple cameras and scenes switched quickly
    It has something to do with DGNVTools. When you index the file, it will demux the audio, and write the delay value into the filename. If you use megui to mux, it will use that delay value
    Is the file in sync?
  6. Yes the source file is in sync. If I were to demux and remux the file, the audio is still in sync with no delay. It seems to be MeGUI that's causing the delay but I don't know why. Maybe MeGUI is using a buggy demuxer.
    I was told by the author of Simple x264 Launcher that the x264 codec default is 250 unless you specify one which I didn't? So does x264 not use 250 as the default? Don't understand why MeGUI uses a KeyInt to 500 when I didn't set that.
    What kind FF/RW problems do you get with KeyInt at 500? Don't want to use KeyInt of 50 so what is the max I can use without causing seek problems? 250?
    When I use DGIndex on standard definition MPEG2s it does indeed specify at "delay 0" for example in the file name. But DGIndexNV does not seem to mention delay in the file name on TS or MKV HD files.
  7. Originally Posted by VideoFanatic View Post
    No , it's using tsmuxer to mux with the delay . Do you see where it says timeshift=65571ms ? It's more than coincidence that the ac3 file has Delay 65571ms written in the name
    ---[NoImage] A_AC3, "E:\2 = New\f0tqqgwk.pyf\Le Mans 24 Hour 2014 Race - [0] English Delay 65571ms.ac3", timeshift=65571ms, lang=eng
    See the last post. It's in the advanced settings GOP calculation FPS based. Change it to fixed or override it with commandline
    Typically seeking will be slow, and some players will pixellate on the seek, before taking a few seconds to recover the picture. But you might not see these issues because of the source characteristics (see the edits in the last post), or some BD players are just super powerful and can play almost anything without problems
    100 is safe for 720p50, because that's what's used for 2sec blu-ray GOP rules, and that' s what you're using otherwise for the other settings
    It's not always "0ms" for SD MPEG2 sources
  8. On the command line I entered --keyint 250 however MeGUI still used 500. Seems to be a bug. Here's the log.
    I don't understand what you're trying to say? If I were to demux the source with TSmuxer or DGIndexNV then mux back with TSMuxer then there would be no delay. Seems to be something that MeGUI is doing that causes the 61 second delay.
  9. Originally Posted by VideoFanatic View Post
    My understanding is the custom commandline in megui should override everything. So indeed it looks like a bug. You should report it
    I'm saying whatever megui is using to demux the file that delay is detected and written ito the filename. I'm assuming it was DGIndexNV, but it's not clear in the log. No matter what muxer you use, it will use the same delay value to "fix" the delay when muxing. In that example tsmuxer was used for muxing. That' s what the log file says. If you had chosen mkv, it would have use mkvmerge, and use the same delay.
    You have the option delete intermediate files enabled, that's why you don't see the audio or other files
    ---[Information] [22/07/2014 16:48:14] Successfully deleted E:\2 = New\f0tqqgwk.pyf\Le Mans 24 Hour 2014 Race.avs
    ---[Information] [22/07/2014 16:48:14] Successfully deleted E:\2 = New\f0tqqgwk.pyf\Le Mans 24 Hour 2014 Race.dgi
    ---[Information] [22/07/2014 16:48:14] Successfully deleted E:\2 = New\f0tqqgwk.pyf\Le Mans 24 Hour 2014 Race - [0] English Delay 65571ms.ac3
    ---[Information] [22/07/2014 16:48:14] Successfully deleted directory E:\2 = New\f0tqqgwk.pyf
  10. Thanks. For the 21 hour video I shall try to untick "Delete intermediate files" so I can get the raw .264 file and mux with the audio myself so I don't get a delay.
    I'd still like to get it working properly for encoding to a container as I've lots of other smaller files that it would take too long to manually index and mux myself so I'd like to leave MeGUI to run overnight. Does anybody know how to get MeGUI working as I've just encoded a few 2 hour episodes and they too had a delay, an even bigger delay of 1 minute 20 seconds! There was no delay in the source. Seems to be fine with 45 minute long videos or less but 2 hour videos get a massive delay.
  11. Is the delay value real? When megui finishes muxing, is it out of sync? ie. Should it be muxing without a delay ? Or does the delay actually keep everything in sync? That's a huge delay and suspicious
    If there is a problem you should report it on the megui bugs thread or nothing will get fixed
