I've picked up some WMV files online and would like to burn VCDs of them. How can I convert them to MPEG-1 format? I've tried Premier 6, Roxio 5, and Ulead DVD Movie Factory.
Is there a codec for this or has someone found an easy way to do it?
I did come across a long, convoluted way to do it using GraphEdit from the Microsoft DirectX 8 SDK, but that sounds like a real pain in the butt.
Any and all help will be appreciated.
Mike Mitchell
Yeah there's an easier way. I did the same a while ago. Get TMPGEnc, this will encode them into Mpeg. You have to load each one into TMPGEnc and adjust the settings each time, when you have loads it's a pain.
You will have to mess around with the settings i.e source aspect ratio, as I simply converted to Mpeg for my viewing on my pc. Encode some small clips at 4:3 and 16:9 and see which looks best.
Mine look great but I haven't done it for standalone.
HTH. :P -
Thanks for the info!
I'm running TMPGenc right now and it seems to be working. I'll play with the settings and see what works best for me. I do plan to burn them to VCD so I can watch on TV.
When I figure out what settings work best, I'll post that info.
What should I convert WMV to?
By videohalp in forum Video ConversionReplies: 3Last Post: 1st May 2009, 17:06 -
Cant convert to WMV
By batmax in forum Video ConversionReplies: 4Last Post: 11th Sep 2008, 02:17 -
How to convert wmv clip so its properties match other wmv clips
By sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 10:16 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53 -
How do i convert rmvb to wmv?
By jimnim in forum Video ConversionReplies: 1Last Post: 9th Jun 2007, 00:22
